[GRASS-user] using other projection
help we with using conical equal area projection for maps in GRASS
Hello Mohammed,
could you be a bit more explicit ? what is your problem ? where is
located your data ? and so on...
No one can really guess what you need.
VB
grass-user mailing list
grass-user@lists.osgeo.org
Perhaps a good way to proceed is to read some documentation for a first
approach. This document
https://subversion.gdf-hannover.de/dl.php?download=gdf_grass60_v1.2_en.pdf can help you, especially chapters 4 to 6.
In a few words, you have to create a location according to your
projection parameters (type, datum, ellipsoïd, etc.), another location
in XY coordinate without geocoding in which you import your rasterized
map. Then you can proceed georeferencing from local location towards
target location.
Good luck,
Vincent.
Le jeudi 22 janvier 2009 à 07:46 -0800, Mohammed Rashad a écrit :
i need to use conical equal area because my maps are done using it. i
scanned the maps and want to create a conical equal area (Albers equal
area) with two standard parallels. so please send the steps in
georeferencing those maps into the above projection
