Greetings
I have used r.statistics to calculate the sum of a cover map based on a base map. When I use the Query tool I get these:
598666.544966|9159452.159237||3996|7108
The first two corresponds to Geographic Location the third Base map clump ID and the last one it corresponds to the value of the sum (r.statistics).
When I try to use this output, in mapcalc, it does not use the values obtained in r.statistics but the clump value Which does not make much sense. How can I use the r.average valeus of this raster?
Thanks
Antonio Rocha
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5918 (20110301) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
Antonio,
since the calculated statistics are stored as labels in the output map, you have to use the @ operator in the mapcalc formula in order to access the labels instead of the clump categories, in your case.
Christian.
-----Ursprüngliche Nachricht----- From: António Rocha
Sent: Wednesday, March 02, 2011 11:10 AM
To: GRASS user list
Subject: [GRASS-user] Using output from r.statistics
Greetings
(r.statistics).
Thanks
Antonio Rocha
http://www.eset.com
grass-user mailing list
grass-user@lists.osgeo.org
