Hello.
I'm having a difficult time finding sample code that uses the output of v.distance as input northing and easting for r.water.outlet. I am attempting to delineate multiple watersheds, each of which has a pour point that must be snapped to the streams before r.water.outlet will run properly. I can get as far as printing the proper coordinates, but, as I am somewhat new to Linux in general, I cannot figure out the proper syntax to pipe it into the next command.
At this point I have the examples provided in v.distance to work from. I have something like this:
echo "484336|234572.699|1" | v.in.ascii output=pnt1
v.distance from=pnt to=map_to_query upload=cat -p
Is this the proper way to start? IE, should I be doing this one point at a time or should I be entering all 16 points at once into the v.distance function?
Any example code would be GREATLY appreciated!!!
Thanks!
-Damian
View this message in context: http://n2.nabble.com/Using-output-of-v.distance-as-input-for-r.water.outlet-tp2599038p2599038.html
