Hello Sir/Ma’am,
Warm Greetings.
I am Omkar Kadlag from Mumbai,India.I am pursuing Electronics and Telecommunication Engineering majors from K.J.Somaiya Institute of Engineering and Information Technology,Mumbai. I am working on a project “Watershed Analysis using python”.
While using GRASS GIS python console for analysis, I’m unable to get desired results. While giving the input ( as a DEM tile ) in the PowerShell prompt of GRASS GIS Software, it gives an error, as ‘wxpython file’ is not available.
Error -
Starting GRASS GIS…
File “C:\Program Files\GRASS GIS 7.8\gui\wxpython\gis_set.py”, line 43, in
from core.gcmd import GMessage, GError, DecodeString, RunCommand
File “C:\Program Files\GRASS GIS 7.8\gui\wxpython\core\gcmd.py”, line 43, in
from win32file import ReadFile, WriteFile
ImportError: DLL load failed: The specified procedure could not be found.
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the --text flag.
Use ‘–help’ for further options
grass78 --help
See also: https://grass.osgeo.org/grass78/manuals/helptext.html
Exiting…
Press any key to continue . . .
Then I made a new environment in the anaconda prompt, where I installed ‘wxpython’ and was successfully able to run GRASS GIS software, but now the issue is I can’t use the command prompt for my analysis. Then I tried to give inputs in the anaconda command prompt but was still unable to get correct outputs.
Error:
(base) PS C:\Users\Omkar> conda activate geopandas_env
(geopandas_env) PS C:\Users\Omkar> cd 'C:\Program Files'
(geopandas_env) PS C:\Program Files> grass78 --gui
Starting GRASS GIS…
WARNING: Concurrent mapset locking is not supported on Windows
Cleaning up temporary files…
/ / __ / | / / / / __/ / /
/ / __/ // / /| | _ \ \ / / __ / / _
/ // / , / ___ |/ // / / // // / / /
_// |// |/// _///_/
Welcome to GRASS GIS 7.8.5
GRASS GIS homepage: https://grass.osgeo.org
This version running through: Command Prompt (C:\WINDOWS\system32\cmd.exe)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
See citation options with: g.version -x
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
Launching GUI in the background, please wait…
Microsoft Windows [Version 10.0.19042.746]
(c) 2020 Microsoft Corporation. All rights reserved.
C:\Program Files>r.in.gdal -e input=“D:\NRSC\Month_Jan\ASTGTMV003_N19E073-dem” output=DEM
ERROR: Unable to open datasource <D:\NRSC\Month_Jan\ASTGTMV003_N19E073-dem>
C:\Program Files>
I want solutions where I can run GRASS GIS directly from the command line and implement my solutions on that.
Yours Sincerely,
Omkar.
