My apologies if this is a repeat post, but i think my question did not get delivered last try. (I’m new here!)
I am looking for a way for GRASS to do create one output raster based on the analysis of say 100 rasters (same spatial coordanates, but each raster has an equal time interval between them).
For example if I have 100 rasters that have only 0’s and 1’s, and I want to calculate an output raster that shows how long it took each cell to first acquire a value of 1. Another example: sums up all 100 rasters to one output raster.
From what I’ve gathered, I think that r.mapcalc will do the necessary functions, but I cannot find an example where it is processing 100s of rasters in a temporal set.
Am I correct in assuming that r.mapcalc is the best solution for my problem? Are there other functions I should know about? Is there any examples that are similar to my problem?
delivered last try. (I'm new here!)
For example if I have 100 rasters that have only 0's and 1's, and I want
raster.
From what I've gathered, I think that r.mapcalc will do the necessary
delivered last try. (I'm new here!) I am looking for a way for GRASS to do
them). For example if I have 100 rasters that have only 0's and 1's, and I
one output raster.
>rasters in a temporal set.Am I correct in assuming that r.mapcalc is the
You can use "r.mapcalc" to achieve (almost) everything. Yet, for time-series,
you can use the module "r.series".
