please help me solving a problem concerning r.mapcalc:
my intention is to calculate a new map consisting of two older ones. the one
shows digitized elements( rocks), cat values are NULL or 1,
the other is a reclassified map(slope >50), with cat values 1 or NULL.
so i have 4 options:
pixels, with only digitized elements, pixels with only slope elements, pixels with both and pixels without(NULL)
the resulting map sould consist of these 4 categories.
i already tried r.patch, but with no success, there was only one resulting category and NULL values.
means:
where both maps are NULL, result will be NULL
where map2 is not null, result will be 1
where map1 is not null, result will be 2
where both maps are not NULL, result will be 3
j
2007/2/9, Thomas Drüssler <Sommes@web.de>:
Hello everybody
Thomas Drüssler <Sommes@web.de>, [20070209 - 15:52:53]
Hello everybody
the one shows digitized elements( rocks), cat values are NULL or 1,
NULL. so i have 4 options:
elements, pixels with both and pixels without(NULL) the resulting map
sould consist of these 4 categories. i already tried r.patch, but
values.
what about
r.mapcalc "newmap = map1 + map2"
Best
Stephan
Stephan Holl <stephan.holl@intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
In general, it's easier to work with 0/1 for "boolean" maps rather
than null/1.
In GRASS, a null value means "no data" or "unknown". IOW, null *isn't*
interpreted as a specific category or value, but as a "marker" for an
unknown value.
E.g. in your second example map, if a value of 1 means that slope>50,
then the "natural" interpretation of a null value is that it is
unknown whether or not slope>50, *not* that slope<=50.
pixels with both and pixels without(NULL) the resulting map sould
consist of these 4 categories. i already tried r.patch, but with no
To the others' explainations I'll add that it is often nice to use
r.support to give your new categories a label / meaning. Then when you
create a legend you don't need to figure out what you meant by "cat 3".
