[GRASS-user] Using r.reclass
Hi
I have a raster image that ranges from 1-300 and I want to apply reclass in order to reclass this image. But I only want to change 10 values (1,10,12,15, 100, 130, 200, 230, 250,290) and the rest I want them to be Null. in the rules file, shall I include the rest of the values and attribute them the null() value or what shall I do?
THanks
Kat
Add the rule:
  * = NULL
Ok Thanks Glynn. It worked
and in the case of pixel-value for wich I dont define any value? R.reclass attributes NULL to it?
2010/10/20 Glynn Clements <glynn@gclements.plus.com>
Add the rule:
  • = NULL
> Add the rule:
> * = NULL
"* = ..." sets the default rule, which applies to any value which
isn't assigned explicitly.
