[GRASS-user] using r.resamp.stats- When I reach a tie
Greetings
I'm planning on using r.resamp.stats in order to resample a grid to a coarser resolution. Since I'm using this function with classes I will use mode method (more frequentclass to fall into a destination cell is the chosen). My question is: when I have a tie between two classes, how does GRASS decides which class shall be chosen?
Thanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5906 (20110225) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
In the event of a tie, the lowest-numbered category is chosen.
Hi Glynn.
Thanks for your answer. Is there any other alternative, to resample data, that uses another approach to solve tie events?
THanks
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5912 (20110227) __________
http://www.eset.com
What mechanism do you want?
If you wanted e.g. the highest-numbered category, you could use
r.mapcalc to create a map with the categories negated, run
r.resamp.stats on that, then negate the result.
Some other possibilities could reasonably be handled with a
combination of pre- and post-processing.
For others, the only practical solution is to modify
lib/stats/c_mode.c.
