[GRASS-user] Using r.sun to get shadowed areas
I’m using r.sun to extract shadowed areas from a LIDAR derived DTM for some date/hour combinations. (GRASS 7.2) According to the man page:
“A map of shadows can be extracted from the solar incidence angle map (incidout). Areas with zero values are shadowed.”
In my output incidout raster, there are never values of zero. The minimum incident angles are quite small, but no zeroes. However the NULL pixels seem to be exactly the shadowed areas. (I am comparing with ortho-photos taken at those specific dates and hours). Am I mistaken, or should the documentation be changed to “Areas with NULL values are shadowed”.
Thanks
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Yes, you are right, I fixed it, thank you.
Anna
On Wed, Nov 22, 2017 at 7:27 AM, Micha Silver <tsvibar@gmail.com> wrote:
I'm using r.sun to extract shadowed areas from a LIDAR derived DTM for some
"A map of shadows can be extracted from the solar incidence angle map
(incidout). Areas with zero values are shadowed."
be changed to "Areas with NULL values are shadowed".
Thanks
Micha Silver
Ben Gurion Univ.
grass-user mailing list
grass-user@lists.osgeo.org
Cheers!
Anna
On Wed, Nov 22, 2017 at 7:27 AM, Micha Silver [<tsvibar@gmail.com>](mailto:tsvibar@gmail.com) wrote:
Thanks
Micha Silver
Ben Gurion Univ.
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
+972-523-665918
