i want to use v.digit with two overlayed raster maps, both of which cover the entire area i’m working, so i need the raster “on top” be translucent to some extent (say, %50 opacity)
is there a way to do that with the bgcmd argument of v.digit?
On Thu, 2008-07-31 at 14:45 -0300, Juan Manuel Barreneche wrote:
hello users!
cover the entire area i'm working, so i need the raster "on top" be
thank you all,
Juan
I am not aware of how something like this could be done
2008/7/31 Juan Manuel Barreneche <jumanbar@gmail.com>:
the entire area i'm working, so i need the raster "on top" be translucent to
I guess not possible in Tcl/Tk-based v.vdigit, if you use grass64 try wxGUI, see
On Thu, Jul 31, 2008 at 08:05:56PM +0200, we recorded a bogon-computron collision of the <landa.martin@gmail.com> flavor, containing:
I'd not say "not possible", but rather "a pain." One could do it by making
a blended raster with r.blend prior to entering v.digit, then using the d.rast
command on that for v.digit.
Or at least, that's what would spring to my mind as the work-around.
No.
However, you can use r.blend to produce a blend between two maps, then
use the blended map as the background.
