Hi list,
in order to use v.line.center properly I use v.category to adjust category assignment.
As a result I get:
GRASS 6.2.2 (admeurop):> v.category in=bound1 layer=2 out=boundary1 --o
WARNING: The vector ‘boundary1’ already exists and will be overwritten.
116 new centroids placed in output map
Building topology …
711 primitives registered
Building areas: 100%
119 areas built
28 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 631
Number of primitives: 711
Number of points : 0
Number of lines : 0
Number of boundaries: 592
Number of centroids : 119
Number of areas : 119
Number of isles : 28
Number of incorrect boundaries : 299
Then I use v.line.center to get the middle points of the boundaries (That’s right?). Then I get the following result:
GRASS 6.2.2 (admeurop):/scratch/manuel/GISDATA/scripts > v.line.center in=boundary1 out=points1 --o
0 categories read from map
0 records selected from table
0 categories read from map exist in selection from table
0 categories read from map don’t exist in selection from table
0 records updated/inserted
0 update/insert errors
WARNING: The vector ‘points1’ already exists and will be overwritten.
Building topology …
0 primitives registered
0 areas built
0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Done.
So, I get nothing
Any can me help? I don’t understand this result.
cheers
Manuel
Manuel Sangiao wrote:
in order to use *v.line.center* properly I use* v.category*
As a result I get:
Number of lines : 0
Then I use *v.line.center* to get the middle points of the
boundaries (That's right?). Then I get the following result:
So, I get nothing
Any can me help? I don't understand this result.
use v.type to convert boundaries to lines first.
Hamish
Thanks Hamish for your help,
that was helpful. But now, when I use v.line.center, I get the following error:
WARNING: Cannot get point on line: cat=927 offset=89379.795093 (line lenght=2.219076)
P 927 927 89379.795093
I guess the reason for this error is the projection (mapset?) unit. The projection unit(s) in my mapset is degree(s). And the length units are meters.
So, how can i change the mapset units. Should I create another mapset with the properly units?
regards
Manuel
2008/6/5, Hamish <hamish_b@yahoo.com>:
in order to use v.line.center properly I use* v.category*
As a result I get:
Number of lines : 0
So, I get nothing
Hamish
Manuel Sangiao pisze:
WARNING: Cannot get point on line: cat=927 offset=89379.795093 (line lenght=2.219076) P 927 927 89379.795093
units are meters.
v.line.center as it is can't work in latlon Location. It uses v.to.db
for length calculation, which cannot measure in degrees, and then pipes
the result to v.segment, which assumes Location unit - if it's degree
the script won't work.
It would be cool if v.segment could accept offsets in various units.
I should fix v.line.center to check location units, and update the
manual. Someday.
Reproject the data into a metric location.
Maciej Sieczka
www.sieczka.org
2008/6/5 Maciej Sieczka <tutey@o2.pl>:
I have created for that trac ticket
http://trac.osgeo.org/grass/ticket/182
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
units are meters.
I think it can... from the man page:
"When calculating perimeters in Latitude-Longitude locations, the geodesic
distance between the vertices is used.
Maybe the problem is different? remember to add "-x" to the first
line of v.line.center to obtain detailed steps of processing (shell
debugging).
Markus Neteler pisze:
units are meters.
v.line.center uses v.to.db to calculate lengths of input vector lines, which then are fed into v.segment as offsets to create lines' center points.
v.segment expects offsets in units of the Location. If these are degrees we have a problem because v.to.db can't calculate length in degrees. It supports the following units:
mi,miles,f,feet,me,meters,k,kilometers,a,acres,h,hectares
Therefore, v.line center can't work in latlon locations.
Maciej Sieczka
www.sieczka.org
after the reprojection in another mapset I used v.line.center, all ok. But, I obtain a new layer without database. The input layer have database.
v.db.connect -p glines1
Vector map is connected by:
layer <2> table in database </scratch/manuel/GISDATA//admprojected/manuel/dbf/> through driver with key
That is the result of all:
GRASS 6.2.2 (admprojected):~ > v.line.center in=glines1@manuel layer=2 out=pts1 --o
587 categories read from map
WARNING: The vector ‘pts1’ already exists and will be overwritten.
WARNING: Cannot get point on line: cat = -1 offset = 171.957102 (line
length = 23.086715)
P -1 -1 171.9571019845255080
Building topology …
586 primitives registered
0 areas built
0 isles built
Attaching islands:
Topology was built.
Number of nodes : 586
Number of primitives: 586
Number of points : 586
Number of lines : 0
Number of areas : 0
Number of isles : 0
Done.
GRASS 6.2.2 (admprojected):~ > v.db.connect -p pts1
ERROR: Database connection for map is not defined in DB file
I have read that the result layer (pts1) contains the category numbers of the input vector line layer.
Is there a solution?
Manuel
database.
v.line.center does not copy the input vector's table to output vector.
v.db.connect -p glines1 Vector map <glines1> is connected by: layer
<2> table <glines1> in database </scratch/manuel/GISDATA//admprojected/manuel/dbf/> through driver
<dbf> with key <cat>
Yes. As the category numbers are the same, you can:
# given that the name of the v.line.center's input vector is "lines" and
# the output is "points":
# copy the input table:
db.copy from_table=lines to_table=points
# connect the table "points" to vector map "points":
v.db.connect points table=points
Now query (d.what.vect, v.db.select) to check if everything's OK.
Mind that I assume plenty of defaults in the example above - verify your
layer number, key column name etc. Refer to to commands's manuals.
Maciek
Maciej Sieczka
www.sieczka.org
Dzie,kuje bardzo Maciej,
It has worked,
2008/6/6 Maciej Sieczka tutey@o2.pl:
database.
v.line.center does not copy the input vector’s table to output vector.
v.db.connect -p glines1 Vector map is connected by: layer
with key
given that the name of the v.line.center’s input vector is “lines” and
the output is “points”:
connect the table “points” to vector map “points”:
Now query (d.what.vect, v.db.select) to check if everything’s OK.
layer number, key column name etc. Refer to to commands’s manuals.
Maciek
Maciej Sieczka
www.sieczka.org
