[GRASS-user] Using v.surf.rst
I’m very new to GRASS and an experienced programmer.
My goal is to import isolines (elevation lines) as well as elevation points from another mapping program into GRASS and then interpolate a raster based on the vector data and then export as a DEM file.
To that end I have reviewed
http://grass.osgeo.org/grass64/manuals/html64_user/v.in.ascii.html
http://grass.osgeo.org/grass64/manuals/html64_user/v.surf.rst.html
I think I understand the principals but am getting stuck on several details.
As a simple test I attempted to create an ASCII file with X Y Z coordinates:
myFile.txt
593493|4914730|123
591950|4923000|222
589860|4922000|232
590400|4922820|143
593549|4925500|442
600375|4925235|342
import with
v.in.ascii –z input=myFile.txt output=secondTry z=3
I get v.in.ascii complete (no error messages)
and then
run v.surf.rst input=secondTry@PERMANENT elev=secondTryRaster
This yields the error
some points outside of region – will ignore…
there are points outside specified 2D/3D region–ignored 6 points
ERROR2: zero points in the given region!
ERROR: Input failed
Keeping in mind I’m completely new to GRASS (and don’t understand a lot of the jargon), can you explain what I’m doing wrong?
Also, can you recommend a tutorial that covers this type of conversion oriented toward beginners?
Thanks!
Eric
After importing the data points, I do not see anything at all visually in GRASS GIS Map Display.
Hello Eric
there are points outside specified 2D/3D region--ignored 6 points
ERROR: Input failed
Probably, you aren't defining the working "region". See command
g.region.
Example: g.region -a vect=secondTry@PERMANENT res=10 -p
This command will define the working region by the spatial extent of
"secondTry", defining and aligning a 10 meters resolution with the
region extent and printing the result.
I strongly suggest the book OPEN SOURCE GIS - A GRASS GIS Approach, 3rd
edition.
Luís Ferreira
Eric pisze:
myFile.txt
593493|4914730|123
591950|4923000|222
589860|4922000|232
590400|4922820|143
593549|4925500|442
600375|4925235|342
import with
and then
some points outside of region -- will ignore...
ERROR: Input failed
Thanks!
Eric
grass-user mailing list
grass-user@lists.osgeo.org
It simply menas that data are outside your region
try:
g.region vect=secondTry
HTH
J.
Awesome! Importing the points worked.
My real source data is defined as a combination of points (which I can now import) and 2D splines (representing the isolines) that may or may not form a closed shape, like this:
|2D Smooth Polygon:
| Height 2885
| smoothing method: Cubic B-Spline
| node 1 at 564.51807,742.19873
| node 2 at 249.51805,570.15057
| node 3 at 578.43365,137.50000
| node 4 at 919.99994,451.23495
| node 5 at 708.73486,742.19879
| node 6 at 541.74695,727.01807
I can easily reformat the data.
How do I import a spline like this into GRASS in preparation for v.surf.rst (or other vector to raster methods)?
Thanks!
Eric
