I have a vector layer of 100000 polys and have noticed some odd behaviour. There is a long delay of a couple of minutes on opening the attribute table (i’m accessing (Postgresql/postgis locally at present). Also when the layer is open applying a simple query in the attribute table manager fails to get any results it just appears to freeze (not responding). It is does not zoom to attribute like other layers but zooms out to map extent instead. I have checked topology with v.build and it seems all okay.
Does anyone else get this with larger vector layers?
Paul J. Shapley
