[GRASS-user] Using Vector Digitizer in Windows
Hi
I’m using Vector Digitizer in MS-Windows (Tcltk since WxGUI is not available) and I wanted to know How can I put an image as a background? I am at v.digit form and I cannot see any field regarding that
Thanks
Kim
On Wed, Jun 2, 2010 at 6:10 PM, Kim Besson <kimbesson1981@gmail.com> wrote:
Hi
I'm using Vector Digitizer in MS-Windows (Tcltk since WxGUI is not
There should be, when starting, the option to select a background display
*command*
http://grass.osgeo.org/grass64/manuals/html64_user/v.digit.html
which could be set to
d.rast map=name_of_raster
Kim:
Markus:
background display *command*
also you can do it in the settings controls once in the tool, there's a
tab for it.
Hamish
Where can I find that tab? I can’t find it at TclTkDigitizer
2010/6/3 Hamish <hamish_b@yahoo.com>
Kim:
Markus:
background display command
also you can do it in the settings controls once in the tool, there’s a
tab for it.
Hamish
Once you start the digitizer, there’s a button “Open Settings” (with colored stripes). In the setting window you’ll see a tab Background. There you click “Add command” and type in a d.rast command to show some background.
Micha Silver
[http://www.surfaces.co.il/](http://www.surfaces.co.il/)
Arava Development Co.  +972-52-3665918
