[GRASS-user] Using wildcards or regular expressions in r.gui.animation?
Hi
is it possible to specify the names of the raster maps to be animated by
using UNIX style wild cards as in r.out.mpeg, i.e.
| g.gui.animation rast="rain[1-9]","rain1[0-2]"
is not working. It would be very useful to be able to use these.
Second question concerns the different panels:
Can I specify these from the commandline?
My reasoning is that I would like to check different time series, and
each one has a slightly different name - being able to use UNIX style
wild cards would make y life so much easier.
Rainer
Rainer M. Krug
animated by using UNIX style wild cards as in r.out.mpeg, i.e.
use g.mlist.
for example:
r.patch out=mosaic.dem in=`g.mlist rast patt=tile.* sep=,`
there's another example in the r.series help page.
Hamish
Hamish <hamish_b@yahoo.com> writes:
use g.mlist.
for example:
True - should have thought about this. Could an example using g.mlist
added to the g.gui.animation manual?
Rainer
Hamish
grass-user mailing list
grass-user@lists.osgeo.org
Rainer M. Krug
use g.mlist.
for example:
Done in r58184.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
i.e.
use g.mlist.
for example: r.patch out=mosaic.dem in=`g.mlist rast
patt=tile.* sep=,`
g.mlist added to the g.gui.animation manual?
Done in r58184.
Thanks a lot,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax : +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
-----BEGIN PGP SIGNATURE-----
Version: GnuPG/MacGPG2 v2.0.22 (Darwin)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJSf5paAAoJENvXNx4PUvmClPYH/252yvmHBBqcu10s8lw+LNFn
QAmpqOtG6Q3IbZfxRtplAi7e+fMEPMq8ShFlftCjcRR8ljryYiuJX+j+7Z9LA4zz
bPhoSAegtjTjmmC+mhcDC8NgYy8BdnTOl6TWkl+rqpNd1uiXGc90eLekcYVMqJCe
WlpSE4PhFNPHcWolSakvxrvtucny3jSV8yCl7cFjM35dRPtxfQhVWM7Jk5BrMXiK
XXz22qdKmjLKJfHxepivWcP2Dd8Zmrz50fyQRInbXLRKgwDP/OieoMxfKNAA9/G9
8ANq+8CJKbl89npLgw5WiluaNNVzmwhegEdGK5TV+mPHMsZ2gCyZ+Zys+BEkGhY=
=7R7H
-----END PGP SIGNATURE-----
