[GRASS-user] /usr/lib/grass/scripts/r.in.wms: line 439: /usr/lib/grass/etc/r.in.wms/r.in.gdalwarp: Argument list too long
Hamish wrote:
Download tiles instead for such a big job... then maybe use r.patch
to combine them into 5x5 degree tiles. Processing should be much more
accurate and faster too.
(I mean standard SRTM tiles, not precut WMS tiles)
you can set up some wget, curl, lftp, httrack script to download them
all for you. see the MODIS(?) grass wiki page for a hint.
actually it's the AVHRR page, not MODIS:
  http://grass.osgeo.org/wiki/AVHRR#Download
see also:
http://grass.osgeo.org/wiki/SRTM#Download
for already downloaded tiles you'd have to follow the rest of the
r.in.gdalwarp and r.in.wms script by hand. It's probably easier/faster
to try the {r.in.srtm or r.in.gdal} + g.region rast=1,2,3,4 + r.patch
in=1,2,3,4 method.
Hamish
Well, download was already done when I cried for help =]
7 gigs....
in=1,2,3,4 method.
nice tip, thanks.
As for 64 bit, my processor is 64bit, but a 32 environment.
Most of the time I just do "desktop" stuff - i.e. youtube, email....
and was struggling with the system.
Also, I just have 2Gigs memory, so, not a big gain anyway.
Paulo Marcondes = PU1/PU2PIX
-22.915 -43.224 = GG87jc <= Corrected !
-23.578 -46.671 = GG66pk
On Tue, 26 May 2009 23:58:25 -0700 (PDT),
see also: http://grass.osgeo.org/wiki/SRTM#Download
in=1,2,3,4 method.
I've found the same problem with r.in.wms on a region that ended up
downloading ~1300 files with this call (from the grass book):
r.in.wms layers=global_mosaic mapserver=http://wms.jpl.nasa.gov/wms.cgi \
    out=wms_global_mosaic_nc
The files downloaded fine, but as Hamish pointed out, then the 'input'
argument for 'r.in.gdalwarp' called from 'r.in.wms' didn't like taking
so many files.
If the files are already downloaded, having proper georeferencing
header:
---<--------------------cut here---------------start------------------->---
gdalinfo $GISDBASE/wms_download/wms_global_mosaic_nc__0.geotiff
Driver: GTiff/GeoTIFF
Files: wms_global_mosaic_nc__0.geotiff
Size is 999, 1002
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.2572235630016,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-66.918579101562500,56.034400939941406)
Pixel Size = (0.000239810426137,-0.000134580390295)
Metadata:
  AREA_OR_POINT=Area
  TIFFTAG_SOFTWARE=SGI's Image Format Library/1.2
  TIFFTAG_MINSAMPLEVALUE=0
  TIFFTAG_MAXSAMPLEVALUE=255
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( -66.9185791, 56.0344009) ( 66d55'6.88"W, 56d 2'3.84"N)
Lower Left ( -66.9185791, 55.8995514) ( 66d55'6.88"W, 55d53'58.38"N)
Upper Right ( -66.6790085, 56.0344009) ( 66d40'44.43"W, 56d 2'3.84"N)
Lower Right ( -66.6790085, 55.8995514) ( 66d40'44.43"W, 55d53'58.38"N)
Center ( -66.7987938, 55.9669762) ( 66d47'55.66"W, 55d58'1.11"N)
Band 1 Block=999x2 Type=Byte, ColorInterp=Red
Band 2 Block=999x2 Type=Byte, ColorInterp=Green
Band 3 Block=999x2 Type=Byte, ColorInterp=Blue
Band 4 Block=999x2 Type=Byte, ColorInterp=Undefined
---<--------------------cut here---------------end--------------------->---
I figured one can use 'gdalwarp' to bring them to the current location:
eval $(g.region -g)
gdalwarp -s_srs 'EPSG:4326' -t_srs="$(g.proj -wf)" -te $w $s $e $n $GISDBASE/wms_download/wms_global_mosaic_nc__0.geotiff ~/tmp/test.tif
and then one could 'r.in.gdal' them into the location for r.patch'ing,
but this doesn't seem right because 'gdalwarp' took several minutes to
run and the output file was ballooning beyond 2 Gb, when the source file
is only 4 Mb. I can't see what's wrong with this.
Seb
I should have mentioned that before trying with 'gdalwarp', I tried what
'r.in.wms' does with 'r.in.gdalwarp', but it also failed with:
$ /usr/lib/grass64/etc/r.in.wms/r.in.gdalwarp in='wms_global_mosaic_nc__0.geotiff,wms_global_mosaic_nc__1.geotiff' out=test s_srs='EPSG:4326'
Creating output file that is 1054P x 1056L.
Processing input file wms_global_mosaic_nc__0.geotiff.
0...10...20...30...40...50...60...70...80...90...100 - done.
ERROR: Projection of dataset does not appear to match current location.
       Location PROJ_INFO is:
       name: Albers Equal Area
       datum: wgs84
       towgs84: 0.000,0.000,0.000
       proj: aea
       ellps: wgs84
       a: 6378137.0000000000
       es: 0.0066943800
       f: 298.2572235630
       lat_0: 58.2500000000
       lat_1: 57.0000000000
       lat_2: 59.5000000000
       lon_0: -63.0000000000
       x_0: 0.0000000000
       y_0: 0.0000000000
       Dataset PROJ_INFO is:
       proj: aea
       datum: wgs84
       ellps: wgs84
       lat_1: 57
       lat_2: 59.5
       lat_0: 58.25
       lon_0: -63
       x_0: 0
       y_0: 0
       no_defs: defined
       ERROR: units
       You can use the -o flag to r.in.gdal to override this check and use
       the location definition for the dataset.
       Consider generating a new location from the input dataset using the
       'location' parameter.
ERROR: r.in.gdalwarp: r.in.gdal failure.
Seb
