I am using GRASS 6.2 on a Windows XP machine. Its the cygwin build. I
also access it from QGIS 8.1 for windows.
The problem I am noticing is reading in a satellite image (ASTER or
Landsat) and the projection and reference system I end up with. My
imagery is in Geotiff format. Reading the metadata files and the
projection info of the Geotiff of course lists the correct zone, etc.
When I load the image into GRASS via r.in.gdal and tell GRASS to create a
new location, I get a generic x,y system set-up and the UTM projection
zone is 0 (no matter where in the world I have my imagery, been tested on
several sets of images...). I go in and reset the projection, bt once I
exit GRASS, the projection defaults back. Oddly enough, the projection it
creates is consistent in terms of overlays, etc. And even odder, when I
import an image in lat-lon it creates that.
Any suggestions on what I am making a mess of?
Best, Mark Hall
