[GRASS-user] v.breach addon
I want to make a hydrological corrected DEM, using v.surf.rst for
interpolation/aproximation and v.breach to introduce aditional elevation
points at streams.
My spatial reference system is EPSG:3763 ETRS89 / Portugal TM06,
(metrical).
As required in v.breach document:
- each input vect line have a unique category in layer 1;
- input lines not cross themselves;
- input lines not constitute loops;
- the input vector lines not stand out of the input raster DEM;
- the input lines direction is from upstream to downstream.
After creating a DEM using v.surf.rst I want to correct the false sinks
in narrow valleys and sparse points areas. Using v.breach I have as
result two output vectors for streams lines and points but without
entities or attributes. I tried with both PostgreSQL and Sqlite database
connections.
For PostgreSQL connection:
DBMI-Postgres driver error:
Cannot select:
SELECT cat,lcat,z,z_breach FROM topografia.vbreachpoints_2
ERROR: column "z" does not exist
LINE 1: SELECT cat,lcat,z,z_breach FROM
Unable to open select cursor: 'SELECT cat,lcat,z,z_breach FROM
topografia.vbreachpoints_2'
Copy table failed
Table <vbreach_2> does not exist in database
<host=localhost,dbname=grass_pp_muda_pttm06>
The table <vbreach_2> is now part of vector map <vbreach> and may be
deleted or overwritten by GRASS modules
Cannot create index:
create unique index vbreach_2_cat on vbreach_2 ( cat )
ERROR: relation "vbreach_2" does not exist
Cannot create index
Cannot grant on table:
grant select on vbreach_2 to public
Cannot grant privileges on table vbreach_2
Select privileges were granted on the table
Any ideas?
If wanted I'll send the files needed for replication.
Thank you
Luís Ferreira
Luís Ferreira pisze:
I want to make a hydrological corrected DEM, using v.surf.rst for interpolation/aproximation and v.breach to introduce aditional elevation points at streams.
My spatial reference system is EPSG:3763 ETRS89 / Portugal TM06, (metrical).
As required in v.breach document: - each input vect line have a unique category in layer 1; - input lines not cross themselves; - input lines not constitute loops; - the input vector lines not stand out of the input raster DEM; - the input lines direction is from upstream to downstream.
After creating a DEM using v.surf.rst I want to correct the false sinks in narrow valleys and sparse points areas. Using v.breach I have as result two output vectors for streams lines and points but without entities or attributes. I tried with both PostgreSQL and Sqlite database connections.
DBMI-Postgres driver error: Cannot select: SELECT cat,lcat,z,z_breach
FROM topografia.vbreachpoints_2 ERROR: column "z" does not exist LINE 1: SELECT cat,lcat,z,z_breach FROM topografia.vbreachpoints_2 ^
Unable to open select cursor: 'SELECT cat,lcat,z,z_breach FROM topografia.vbreachpoints_2' Copy table failed Table <vbreach_2> does not exist in database <host=localhost,dbname=grass_pp_muda_pttm06> The table <vbreach_2> is now part of vector map <vbreach> and may be
deleted or overwritten by GRASS modules DBMI-Postgres driver error:
Cannot create index: create unique index vbreach_2_cat on vbreach_2
( cat ) ERROR: relation "vbreach_2" does not exist Cannot create
index DBMI-Postgres driver error: Cannot grant on table: grant select
on vbreach_2 to public ERROR: relation "vbreach_2" does not exist Cannot grant privileges on table vbreach_2 Select privileges were granted on the table
Any ideas? If wanted I'll send the files needed for replication.
Luís,
Glad to see someone trying to use my stuff :).
What GRASS version do you use? What OS? What was your command line, exactly?
Maybe the culprit is the DB backend. I have never used the script with
anything else than DBF. Try to switch to DBF in GRASS (db.connect). Or a
GRASS version "too new". I think I used it only against 6.3. There
*might* have been changes to underlying GRASS modules.
I've written the script, and used it the last time, about 2 years ago.
It did the job fine then. I don't have a personal interest in developing
it at the moment. I could provide you a commercial support if you like.
That would include testing the script against your data, in a GRASS
setup similar to yours, and fixing the tool if necessary.
Please contact me in priv if you are interested. I don't charge much :).
Or, if there's a GRASS hacker willing to do it for free - please go
ahead, anybody.
Best,
Maciek
Maciej Sieczka
http://www.sieczka.org
Aftermath...
I had to change some strings to make v.breach work on GRASS 6.4svn
revision 39873, Ubuntu/Debian 9.10.
Luís Ferreira
line 310
v.parallel input="${OUTP}_grid_addcat_bnd_patch_break_ln_2l_tmp_${UNQ}"
output="${OUTP}_segm_2l_r_tmp_${UNQ}" distance=0.00001 --o > /dev/null
and
line 312
output="${OUTP}_segm_2l_l_tmp_${UNQ}" distance=-0.00001 --o > /dev/null
change to
                                v.parallel
output="${OUTP}_segm_2l_r_tmp_${UNQ}" side=right distance=0.00001 --o
/dev/null
                                                v.parallel
output="${OUTP}_segm_2l_l_tmp_${UNQ}" side=left distance=0.00001 --o
/dev/null
line 388
v.db.addcol map="${OUTP}" layer=2 'columns=x double, y double, z double,
z_breach double' > /dev/null
change to
                                'columns=x double precision, y double
                                precision, z double precision, z_breach
                                double precision' > /dev/null
line 474
db.execute input=$TMP.${PROG}.sql database=$dbs driver=$drv > /dev/null
change to
                db.execute input=$TMP.${PROG}.sql database=${database}
driver=
${driver} > /dev/null
change $tbl to $table
v.clean tool=prune
defaulting to treshold=0.0
line 464
change to
table=`v.db.connect -g "${OUTP}" | awk '{print $2}'`
database=`v.db.connect -g "${OUTP}" | awk '{print $4}'`
driver=`v.db.connect -g "${OUTP}" | awk '{print $5}'`
make explicit field separator for awk
awk -F "|"
> (metrical).
Luís,
ahead, anybody.
Best,
Maciek
(attachments)
v.breach_changed (20.5 KB)
Aftermath...
I had to change some strings to make v.breach work on GRASS 6.4svn revision 39873, Ubuntu/Debian 9.10.
Can you send a diff (diff original_file your_file), as attachment?
Maciek
Maciej Sieczka
Here is it :slight_smile:
Luís
> Aftermath...
Maciek
(attachments)
diff.txt (4.35 KB)
The problem with v.breach is down to v.parallel interface change in
v.parallel2 - option `distance' does not accept negative offsets
anymore, and introduces a new `side' option to distinguish left/right,
instead:
$ v.parallel in=lines out=lines_par dist=-1
ERROR: value <-1> out of range for parameter <distance>
        Legal range: 0-100000000
@Devs: It would be cool if v.parallel could be changed to accept
negative offsets, for compatibility within 6.x line.
@Luís: I applied most your of patch. Thanks! Are you sure that's all
errors? I keep on getting warnings like:
WARNING: Unable to get point on line: cat = 1 offset = 2.831711 (line
          length = 0)
at v.segment calls in the script, and a crash at v.in.ascii.
Best,
Maciek
Maciej Sieczka
I used v.breach with both SQLite and dbf, with ETRS89 metric negative
coordinates, from 20m to 2m resolution and worked fine.
System: Ubuntu 9.10 Karmic Koala, 64 bits, GRASS 6.4SVN.
But I remember to see some warnings like yours. Are these warnings
critical? Visually, the interpolated DEMs with v.surf.rst are coherent.
Luís
          length = 0)
But I remember to see some warnings like yours. Are these warnings critical? Visually, the interpolated DEMs with v.surf.rst are
coherent.
I'll let you know next time I take a hobbyist look at v.breach. But I
really don't know when it will be.
Good luck.
Maciek
all errors? I keep on getting warnings like:
(line length = 0)
Maciej Sieczka
Kubuntu 9.10 64bit, using GRASS 6.5.
I ran v.breach on a stream network extracted with r.stream.extract.
It runs through the program, and puts up an error dialogue at
v.parallel. Attached is the log file. It looks like a negative
number is being passed to v.parallel. I saw in the documentation this
might be a problematic module in the script for non-metric coordinate
system. Below is the portion of the output box from the module. Note
the error 11 lines down.
Building topology for vector map <breach_pt_segm_2l_r_tmp_5636_0_v_breach_sh>...
Registering primitives...
100 primitives registered
259 vertices registered
Building areas...
0 areas built
0 isles built
Attaching islands...
Attaching centroids...
Number of nodes: 100
ERROR: value <-0.00001> out of range for parameter <distance>
Number of primitives: 100
Number of points: 0
Number of lines: 100
Number of boundaries: 0
Number of centroids: 0
Description:
Creates parallel line to input vector lines.
Keywords:
vector, geometry
Should I look in the script for this portion, and check if it is a
metric issue? or does this seem like a different problem?
Mark
2009/12/14 Maciej Sieczka <msieczka@sieczka.org>:
coherent.
Good luck.
Maciek
(line length = 0)
Maciej Sieczka
grass-user mailing list
grass-user@lists.osgeo.org
(attachments)
v.breach.log (892 Bytes)
Luis:
I noticed you mentioned you had run it with sqlite and dbf database
drivers. Mine is mapped to sqlite currently. I see some v.to.db
commands in the script, but do I understand correctly that you didnt
have issues using sqlite as backend?
Mark
2009/12/14 Luís Ferreira <lferreira75.1@gmail.com>:
Luís
length = 0)
M S pisze:
Building areas...
0 areas built
0 isles built
Number of points: 0
Description:
Keywords:
vector, geometry
A different one. v.parallel used to accept negative offsets to distinguish left/right. Now (after v.parallel2 replaced it) it doesn't accept negative offsets anymore.
Maciek
coherent.
Good luck.
Maciek
(line length = 0)
Maciej Sieczka
Maciej Sieczka
Yes, it worked with sqlite db connection.
Luís
On Mon, 2009-12-14 at 15:52 -0500, M S wrote:
Luis:
