Hello all.
I have three points for which I create three areas with v.buffer. However, this new polygon map have no attribute table - so I create one with v.category and v.db.addtable. This gives an attribute table with 3 categories but they are all linked to all polygons! I won’t each polygon to have a separate category.
Anyone knows what to do?
Martin
This is fixed only in GRASS 7, here, v.buffer can preserve attributes
in the output. Furthermore, v.buffer in GRASS 6 is not working well,
there are a number of known bugs.
Alternatively, you can delete categories with
v.category option=del cat=-1
followed by
v.category option=add cat=1
Each polygon will then have its own unique category.
HTH,
Markus M
On Tue, Oct 9, 2012 at 1:40 PM, Martin Album Ytre-Eide
<Martin.Album.Ytre-Eide@nrpa.no> wrote:
Hello all.
categories but they are all linked to all polygons! I won't each polygon to
Martin
grass-user mailing list
grass-user@lists.osgeo.org
