[GRASS-user] v.buffer bug??
When I buffer the attached line layer with 250 mapunits I get an unsiutable
result. Take a look of the buffer_error.png image. You will see that the
line at the mean right wasn't buffered correct. To reproduce this behavior I
attach the original line layer.
GRASS-6.1.0
With best regards
Horst Düster
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Amt für Geoinformation
Abteilung SO!GIS® Koordination
Rötistrasse 4
CH-4501 Solothurn
Tel.: ++41 (0)32 627 25 32
Fax: ++41 (0)32 627 22 14
horst.duester@bd.so.ch
www.sogis.so.ch
(attachments)
test_line_shp.zip (6.59 KB)
unsiutable result. Take a look of the buffer_error.png image. You will
see that the line at the mean right wasn't buffered correct. To
reproduce this behavior I attach the original line layer.
GRASS-6.1.0
This is a known bug, see the BUGS section in the v.buffer help page.
Work-around 1: make a buffer half the size, then buffer the result a
second time.
Work-around 2: v.to.rast, r.buffer, r.to.vect
Hamish
GRASS-6.1.0
this is bug #2765 by the way,
http://intevation.de/rt/webrt?serial_num=2765
Hamish
