I'm starting to use v.buffer to create circles around points on
Lat/Long vector maps.
When entering a value for the distance parameter for v.buffer to
create circles for points on lat/long maps, is the distance entered
the radius of the circle or is it the diameter? or some other
variable?
due to changing distances on latitude, the circle is not a true circle, as you can see when you reproject the map.
The buffer distance is in degree.
Hope, everything is correct,
regards,
Achim
Am 03.11.2010 06:44, schrieb Sharon M:
variable?
