[GRASS-user] v.buffer on Grass 6.4.2RC1
I run v.buffer on Grass 6.4.2RC1 but I think there is something wrong with
the results. You can see the results of:
1. v.buffer: http://www.geographer.gr/buffer/grass_buffer.jpeg
http://www.geographer.gr/buffer/grass_buffer.jpeg (v.buffer produced the
small polygons)
2. buffer with qgis (ftools) :
http://www.geographer.gr/buffer/qgis_buffer.jpeg
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-on-Grass-6-4-2RC1-tp6895711p6895711.html
2011/10/15 leonidas <leonidas_liakos@yahoo.gr>:
small polygons)
please report bug on trac [1].
Thanks, Martin
[1] http://trac.osgeo.org/grass/newticket
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
When reporting this but, don't forget to add also sample data - most
likely v.out.ascii output of area causing breakage will be enough.
Maris.
2011/10/15 Martin Landa <landa.martin@gmail.com>:
small polygons)
Thanks, Martin
grass-user mailing list
grass-user@lists.osgeo.org
