I'm using Grass 6.4.0 and I'm trying to generate a buffer for a polyline
vector map. The problem is that v.buffer runs but it doesn't end. I give it
a lot of time (+2 hours) but it didn't finish. Using the same file in QGIS
the job done in less than a minute. What could be the problem? Is this a
bug?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-problem-bug-tp6199121p6199121.html
bug?
Likely yes. Could you please try the 6.4.1RC2 package? This bug was fixed
http://trac.osgeo.org/grass/ticket/994
Perhaps also the former version of v.buffer (the current version is a rewrite)
will be reactivated since it got fixed and performs better:
http://trac.osgeo.org/grass/ticket/699
In any case a test with 6.4.1RC2 is recommended.
Thank you Markus, I'll check it!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-problem-bug-tp6199121p6199313.html
I'm trying to upgrade to GRASS 6.4.1RC2 following the instructions at
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable?field.series_filter=lucid
But grass --version command reports that the version is GRASS GIS 6.4.0
Did I make any mistake?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-problem-bug-tp6199121p6209279.html
Markus Neteler:
bug?
This bug is still present in v.buffer2 and v.parallel2, only v.buffer
/ v.parallel in 6.5 will finish in this case, but v.buffer /
v.parallel in 6.5 is still deactivated by default because some
features still need to be ported from v.buffer2 to v.buffer. To be
done in 6.5, then backported to 6.4.
Markus M
So, what should I do to run successfully the buffer?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-problem-bug-tp6199121p6212654.html
You could compile 6.5 from source, then go to vector/v.buffer, run
make in that directory, optionally install grass and use v.buffer
instead of v.buffer2.
Ok, thank you all! I did it!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/v-buffer-problem-bug-tp6199121p6213730.html
