[GRASS-user] v.buffer segmentation fault
Dear grass developers,
I have a potential bug here, if everything I do is right.
I have a vector calledn england.
I run
v.buffer input=england output=england_buffer type=area buffer=1420
and all I get is segmentation fault.
P.S.: I cannot login anymore into the tracker with my ID (ct529). Can Martin
do anything about it?
Best Regards
Corrado Topi
Global Climate Change and Biodiversity
Area 18,Department of Biology
University of York, York, YO10 5YW, UK
Phone: + 44 (0) 1904 328645, E-mail: ct529@york.ac.uk
I run
buffer=1420
what version of GRASS? what operating system?
can you reproduce the bug with the North Carolina or spearfish
datasets?
(ct529).
can you find your login on the find-my-login-id osgeo wiki
page? (probably linked from the login/create new account page)
Hamish
1) GRASS version: 6.3, 6.4 RC4
Operating system: Linux Kubuntu 9.04 64 bit, FC 9.0 64 bit, Linux Kubuntu 904
32 bit
Which makes me assume this is a bug since the vectors are clean.
Where do I get those datasets?
2) Yes
> I run
> buffer=1420
datasets?
> (ct529).
Hamish
Corrado Topi
Global Climate Change & Biodiversity Indicators
Yes it is reproducible with spearfish:
v.buffer input=landcover output=lcb distance=2 --overwrite
Buffering lines...
100%
Buffering areas...
Segmentation fault
GRASS 6.4.0RC4 (Spearfish60):~ >
It may be a size dependent bug. Small vectors, v.buffer works. Large vectors it
does not.
904 32 bit
2) Yes
> > I run
> > buffer=1420
> datasets?
> > (ct529).
> Hamish
Corrado Topi
Buffering lines...
100%
Buffering areas...
Segmentation fault
Same here with GRASS 6.5:
GRASS 6.5.svn (spearfish60):~ > gdb v.buffer
(gdb) r input=landcover output=lcb distance=2 --o
Starting program:
/home/neteler/grass65/dist.x86_64-unknown-linux-gnu/bin/v.buffer
[Thread debugging using libthread_db enabled]
WARNING: Vector map <lcb> already exists and will be overwritten
Buffering lines...
100%
Buffering areas...
[New Thread 0x7f8b055c4720 (LWP 3392)]
Program received signal SIGSEGV, Segmentation fault.
0x00007f8b051b64c8 in Vect_get_isle_points (Map=0x7fff0d60f6d0,
isle=0, BPoints=0x2362de0) at area.c:118
118 G_debug(3, " n_lines = %d", Isle->n_lines);
I have created a ticket for this:
http://trac.osgeo.org/grass/ticket/699
2009/7/24 Corrado <ct529@york.ac.uk>:
http://grass.osgeo.org/download/data.php
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Dear Martin,
thanks but I had already found them and run the tests (see previous posts).
Thanks anyway!
On Wednesday 29 July 2009 07:20:50 Martin Landa wrote:
Martin
Best Regards
Corrado Topi
