Is anyone aware of a way to get the results of v.build.polylines but keep the attributes and only merge adjacent lines that have the same attributes?
Meaning if one has three lines, where two of them have identical attribute values, and one does not, that the two with identical attributes would be merged (node removed), and keep the node (and separate line) for the line that does not have the same attributes?
Basically I’d like to merge adjacent lines that only have similar attribute values.
attributes?
Basically I'd like to merge adjacent lines that only have similar
attribute
values.
Mark
v.build.polylines operates globally. For selective editing, use v.edit
(GRASS 6.3-CVS).
There are the "connect" and the "merge" tool which should exactly do what
you
need (in combination with SQL where statement).
attributes?
attribute
values.
Mark
(GRASS 6.3-CVS).
you
keep
attributes?
attribute
be
line
attribute
values.
Mark
(GRASS 6.3-CVS).
you
but unfortunatly 'merge' do not work....
It does (for me), I just used it. Please be more specific.
Hi!
I have the same problem: need to merge every adjacent lines with a specific
equal attribute, and need to add some others atributes when the lines are
merged. I tried to solve using the v.edit module and have concluded that the
simple use of this module cannot solve the problem. If I'm wrong, how should
be the WHERE clausle? I believe that the only way out is to build a script
involving several steps...
