I have a vector feature with four areas and two layers. Each of the two layers is tied to a different sqlite table. I'm trying to make what is currently layer 2 the default, and to delete the no longer needed layer 1. I tried
v.category inp=new_ascii op=chlayer type=centroid layer=2,1 out=fixed
WARNING: Database connection and attribute tables for concerned layers are
not changed
Processing features...
but it never stops processing and I have to kill it. The vector feature new_ascii only has four areas, so it's not computationally intensive. new_ascii layer 1 and 2 are both tied to a sqlite table.
I've looked at op=transfer, but haven't had luck with that yet either.
GRASS 7.0.4 on Arch linux if that matters.
Thanks, Dave
I tried
not changed
Thanks for reporting this bug. It has been fixed in all G7 branches
with r69469-71, please try.
The vector feature
What exactly is the problem with op=transfer?
If you want to delete a layer, you need to use v.category op=del
cat=-1 layer=X. After that, you can safely move categories of another
layer to the now unused layer. If in doubt, check first with
v.category op=report.
HTH,
Markus M
Thanks, Dave
grass-user mailing list
grass-user@lists.osgeo.org
