I'd like to better understand the way cat values are assigned to centroids when using v.centroids. I came across a problem when I created a new vector and digitized boundaries (v.digit -n) . Before beginning to digitize, I added some columns to the attribute table within v.digit, so that on completing each feature, I could fill in the values for that feature. I had one column for the label, and one column, GRASSRGB for coloring. I did not bother to digitize centroids, but rather, after completing the boundaries, and exiting v.digit, I ran v.centroids.
I was surprised to see that the cat value assigned to each centroid *does not correspond* to the cat values of the surrounding boundary. This has the unfortunate effect of showing incorrect labels when running d.vect with the display=shape,attr option, since the attribute is taken from centroid, and not from its surrounding boundary. In addition, when coloring with the d.vect -a option, the boundaries get the correct color from the GRASSRGB column, but the fill color is also wrong, since the fill color is again taken from the attributes of the centroid. And the centroid, with a different cat value, goes to the wrong row of the attached attribute table. This behavior is certainly undesirable, unless I'm missing something basic??
My workaround was to delete all centroids, then go back into v.digit, and digitize each centroid, while being careful to choose it's cat value manually, and set each one to the correct cat of the surrounding boundary by choosing "Manual Entry" instead of "Next not used" mode for categories.
So, is there some way to create centroids, such that they automatically get the same cat value as the boundary?
Micha
