Hi everybody,
I have a problem using v.centroids:
I created a map of landscape fragmentation by roads and other linear features, then converted the lines to boundaries with the command
> v.type input=grenzen2 output=grenzen3 type=line,boundary --overwrite <
In the next step I cleand up the map with
> v.clean input=grenzen3 output=grenzen4 type=boundary tool=rmdangle,rmbridge,rmdupl,rmdac,bpol,rmline thres=-1 --overwrite<
because there were still inncorrect boundaries I used the same command once more:
> v.clean input=grenzen4 output=grenzen5 type=boundary tool=rmdangle,rmbridge,rmdupl,rmdac,bpol,rmline thres=-1 --overwrite<
So far so good, but then I treid to attach centroids to my new areas by using
> v.centroids input=grenzen5 output=grenzen6 option=add --overwrite<
the result was
>Number of duplicate centroids : 4266
>Number of areas without centroid : 4266
I tried to manually add some centroids to the areas without centroid by v.digit, and that worked fine, but I don't want to do it for 4266 areas, and I also have no idea why there are areas with duplicate centroids.
Any idea what to do?
Thanks in advance,
Tim
Tim Ritter, B.Sc.
Springstraße 46a
37077 Göttingen
Tel.: 0551 / 389 3 114
Fax.: 0551 / 389 3 115
Mobil: 0173 / 284 3 664
