[GRASS-user] v.class.mlR Error
Dear GRASS GIS community,
I just started working with Grass to try some object-based analysis. I do not have much experience with programming, but learning bits on the go.
The segmentation test with uspo appears to have been ok, but I am struggling with the next step. I was suspecting the training vector created in QGIS wasn’t meeting proper standards, but I could not find a straightforward Grass module for labeling segments/ creating a training set file.
Hopefully someone can help me out.
Command output:
(Tue May 29 14:18:32 2018)
v.class.mlR -i --overwrite training_map=Training_Ben2@haarlooj_Ben_Test segments_file=C:\Users\haarlooj\Documents\CELOS\Stats_Training_Ben_test separator=comma raster_segments_map=best_myregion1_at_haarlooj_Ben_Test_rank1@haarlooj_Ben_Test train_class_column=code output_class_column=vote output_prob_column=prob classifiers=svmRadial,rf,C5.0 folds=5 partitions=10 tunelength=10 weighting_modes=smv,qbwwv weighting_metric=accuracy classification_results=X:\Projecten\Land-use Planning Marowijne\GIS en RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_classifier-Results accuracy_file=X:\Projecten\Land-use Planning Marowijne\GIS en RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_Test_accuracy model_details=X:\Projecten\Land-use Planning Marowijne\GIS en RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_Test_ClassifierDetails bw_plot_file=X:\Projecten\Land-use Planning Marowijne\GIS en RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_classifier_performance r_script_file=X:\Projecten\Land-use Planning Marowijne\GIS en RS\Werkfolder\GRASS\v.class.mIRR_optional_output\Ben_test_R_script processes=3
Running R now. Following output is R output.
File “C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
pts/v.class.mlR.py”, line 633, in
main()
pts/v.class.mlR.py”, line 570, in main
subprocess.check_call([‘Rscript’, r_commands],
stderr=subprocess.STDOUT, )
File “C:\Program Files\GRASS GIS
7.4.0\Python27\lib\subprocess.py”, line 537, in check_call
retcode = call(*popenargs, **kwargs)
7.4.0\Python27\lib\subprocess.py”, line 524, in call
return Popen(*popenargs, **kwargs).wait()
7.4.0\Python27\lib\subprocess.py”, line 711, in init
errread, errwrite)
7.4.0\Python27\lib\subprocess.py”, line 948, in
_execute_child
startupinfo)
WindowsError: [Error 2] The system cannot find the file
specified
(Tue May 29 14:18:33 2018) Command finished (0 sec)
Best,
Jamille
Hi Jamille,
The segmentation test with uspo appears to have been ok, but I am struggling with the next step. I was suspecting the training vector created in QGIS wasn't meeting proper standards, but I could not find a straightforward Grass module for labeling segments/ creating a training set file.
Command output:
File "C:\Users\haarlooj\AppData\Roaming\GRASS7\addons/scri
pts/v.class.mlR.py <http://v.class.mlR.py>", line 633, in <module>
main()
pts/v.class.mlR.py <http://v.class.mlR.py>", line 570, in main
subprocess.check_call(['Rscript', r_commands],
My hunch is that the problem is some PATH issues making it difficult to call R.
Maybe some of the Windows gurus out there could help with this ?
Moritz
My hunch is that the problem is some PATH issues making it >difficult to
call R.
Is there a working example available for this addon?
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Users-f3884509.html
call R.
Here's a complete working example of the entire OBIA chain in the NC dataset (warning: this is a demo example, not necessarily one of best practice ;-)) :
g.extension r.object.geometry
g.extension i.segment.stats
g.extension v.class.mlR
g.region rast=lsat7_2002_10 -p
i.group lsat7_2002_ms in=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
i.segment lsat7_2002_ms threshold=0.05 out=lsat7_segs_005 minsize=10
i.segment.stats lsat7_segs_005 rasters=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70 vectormap=lsat7_segs_stats
v.random n=1000 out=points
v.db.addtable points
v.db.addcolumn points col="class int"
v.what.rast map=points raster=landclass96 column=class
v.db.addcolumn points col="segid int"
v.what.rast map=points raster=lsat7_segs_005 column=segid
v.db.join lsat7_segs_stats column=cat otable=points ocolumn=segid subset_col=class
v.extract lsat7_segs_stats where="class>0" output=training
v.class.mlR segments_map=lsat7_segs_stats training_map=training train_class_colum=class
r.colors.out landclass96 rules=landclass96.colors
v.colors lsat7_segs_stats use=attr column=vote_smv rules=landclass96.colors
d.vect lsat7_segs_stats
Not sure if this should go into the man pages of the different tools, or whether it might be better to integrate it into image classification wiki page's section on OBIA [1] and link to that from the different man pages.
Moritz
[1] https://grasswiki.osgeo.org/wiki/Image_classification#Object-based_classification_and_image_segmentation
practice ;-)) :
thanks, testing it here now.
https://trac.osgeo.org/grass/browser/grass-addons/grass7/vector/v.class.mlR/v.class.mlR.py#L278
278 install_package = "if(!is.element('%s',
installed.packages()[,1])){\n"
279 install_package += "cat('\\n\\nInstalling %s package from
CRAN\n')\n"
280 install_package += "if(!file.exists(Sys.getenv('R_LIBS_USER'))){\n"
281 install_package += "dir.create(Sys.getenv('R_LIBS_USER'),
recursive=TRUE)\n"
282 install_package += ".libPaths(Sys.getenv('R_LIBS_USER'))}\n"
283 install_package += "chooseCRANmirror(ind=1)\n"
284 install_package += "install.packages('%s', dependencies=TRUE)}"
for installling packages in windows R:
https://cran.r-project.org/bin/windows/base/rw-FAQ.html#I-don_0027t-have-permission-to-write-to-the-R_002d3_002e5_002e0_005clibrary-directory
for installing system wide in windows administrator rights are needed. maybe
some possible source of troubles.
so maybe a recommendation in the manual?: let the user install the needed
packages first in R itself, then start the grass addon.
addon test here shows:
v.class.mlR --verbose segments_map=lsat7_segs_stats training_map=training
Loading required package: caret
Loading required package: lattice
Loading required package: ggplot2
There were 50 or more warnings (use warnings() to see the first 50)
Error in file(file, ifelse(append, "a", "w")) :
  cannot open the connection
Calls: write.csv -> eval.parent -> eval -> eval -> write.table -> file
In addition: Warning message:
In file(file, ifelse(append, "a", "w")) :
  cannot open file '.gscript_tmp_model_output_1300.csv': Permission denied
Execution halted
ERROR: There was an error in the execution of the R script.
Please check the R output.
it seems, R is started, packages loaded correctly.
where is the file '.gscript_tmp_model_output_1300.csv' written to?
485 if allmap and not flags['f']:
486 model_output = '.gscript_tmp_model_output_%d.csv' % os.getpid()
487 write_string = "write.csv(resultsdf, '%s'," % model_output
488 write_string += " row.names=FALSE, quote=FALSE)"
489 r_file.write(write_string)
490 r_file.write("\n")
would it be possible to catch the R error/output?
best regards
Helmut
practice ;-)) :
tested here now with -f flag in the GUI:
train_class_column=class output_class_column=vote output_prob_column=prob
folds=5 partitions=10 tunelength=10 weighting_metric=accuracy
classification_results=D:\temp\vclassr\class.txt
accuracy_file=D:\temp\vclassr\acc.txt
model_details=D:\temp\vclassr\details.txt
r_script_file=D:\temp\vclassr\testrunaddon.R processes=3
Loading required package: foreach
Loading required package: iterators
Loading required package: parallel
Warning message:
In nominalTrainWorkflow(x = x, y = y, wts = weights, info = trainInfo, :
  There were missing values in resampled performance measures.
  cannot open file '.gscript_tmp_model_output_2392.csv': Permission denied
Execution halted
attached the testrunaddon.R
<http://osgeo-org.1560.x6.nabble.com/file/t193444/testrunaddon.R&gt;
best regards
Helmut
in the R script:
resultsdf$prob_smv <- vote$V2
write.csv(resultsdf, '.gscript_tmp_model_output_2392.csv', row.names=FALSE,
quote=FALSE)
write.csv(resultsdf, 'D:\temp\vclassr\class.txt', row.names=FALSE,
quote=FALSE)
AFAIR in windows and python, you need to specify the temp file e.g. by
python's tempfile functions that it can be found later in the process.
best regards
Helmut
in the R script:
row.names=FALSE,
quote=FALSE)
quote=FALSE)
as an example I do it in
https://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.euro.ecosystem/r.euro.ecosystem.py#L72
72 # define intermediate folder files
73 datatempdir = tempfile.gettempdir()
74 if level1 :
75 tmp_col_l1 = os.path.join( datatempdir, color_rules_level1 )
76 tmp_cat_l1 = os.path.join( datatempdir, cat_rules_level1 )
77 if level2 :
78 tmp_col_l2 = os.path.join( datatempdir, color_rules_level2 )
79 tmp_cat_l2 = os.path.join( datatempdir, cat_rules_level2 )
maybe there are nicer and more pythonic ways to do it :wink:
best regards
Helmut
in the R script:
quote=FALSE)
quote=FALSE)
Thanks for testing !
You're right. I don't remember why I coded this in that manner. It might have been to ensure the .csv and .csvt suffix needed for db.in.ogr.
Could you try with below patch ?
Moritz
Index: v.class.mlR.py
--- v.class.mlR.py (révision 72333)
+++ v.class.mlR.py (copie de travail)
@@ -233,8 +233,8 @@
          gscript.try_remove(feature_vars)
      if trainmap:
          gscript.try_remove(training_vars)
- gscript.try_remove(model_output)
- gscript.try_remove(model_output_desc)
+ gscript.try_remove(model_output_csv)
+ gscript.try_remove(model_output_csvt)
      gscript.try_remove(r_commands)
      if reclass_files:
          for reclass_file in reclass_files.itervalues():
@@ -251,8 +251,8 @@
      global trainmap
      global feature_vars
      global training_vars
- global model_output
- global model_output_desc
+ global model_output_csv
+ global model_output_csvt
      global temptable
      global r_commands
      global reclass_files
@@ -483,8 +483,9 @@
              r_file.write("\n")
- model_output = '.gscript_tmp_model_output_%d.csv' % os.getpid()
- write_string = "write.csv(resultsdf, '%s'," % model_output
+ model_output = gscript.tempfile()
+ model_output_csv = model_output + '.csv'
+ write_string = "write.csv(resultsdf, '%s'," % model_output_csv
          r_file.write("\n")
@@ -575,10 +576,10 @@
- model_output_desc = model_output + 't'
+ model_output_csvt = model_output + '.csvt'
          temptable = 'classif_tmp_table_%d' % os.getpid()
- f = open(model_output_desc, 'w')
+ f = open(model_output_csvt, 'w')
          header_string = '"Integer"'
          if flags['i']:
              for classifier in classifiers:
@@ -595,7 +596,7 @@
        gscript.message("Loading results into attribute table")
    gscript.run_command('db.in.ogr',
- input_=model_output,
+ input_=model_output_csv,
                              output=temptable,
                              overwrite=True,
                              quiet=True)
unfortunately it seems copy/paste the patch from mail to a diff file doesn't
work, maybe caused by some whitespace or similar.
could you attach the patch as a file?
best regards
Helmut
Yes, obviously. Sorry for that.
I'm a bit under pressure for something completely different and am doing this (too) quickly on the side...
Moritz
(attachments)
v_class_mlR_tempfile.diff (2.14 KB)
no problem.
patch applied:
train_class_colum=class processes=3
Warning message:
Error: '\g' is an unrecognized escape in character string starting "'D:\g"
Execution halted
Error in atexit._run_exitfuncs:
  File "C:\OSGEO4~1\apps\Python27\lib\atexit.py", line 24,
in _run_exitfuncs
    func(*targs, **kargs)
  File "C:\Users\hkmyr\AppData\Roaming\GRASS7\addons/scripts
/v.class.mlR.py", line 237, in cleanup
NameError: global name 'model_output_csvt' is not defined
Error in sys.exitfunc:
in _run_exitfuncs
there seems to be a path issue with shlashes
and some variables not defined.
best regards
Helmut
no problem.
patch applied:
Warning message:
added a g.message about the temporary file:
temporary file: D:\grassdata\nc_spm_08_grass7\user1\.tmp/unknown\10300.3.csv
AFAIR R in windows needs slashes, e.g.
getwd()
[1] "C:/Users/myuser/Documents"
best regards
Helmut
no problem.
patch applied:
Warning message:
getwd()
Right.
Would replacing tempfile() with tempfile().replace('\\', '/') in line 486 help ?
ISTR that there was a function for this somewhere, but can't find it in a quick search.
Attached the again entire patch, but with the above change.
Moritz
(attachments)
v_class_mlR_tempfile.diff (2.16 KB)
no problem.
patch applied:
Warning message:
"'D:\g"
"'D:\g"
temporary file:
getwd()
Right.
486 help ?
a quick search.
yes, looks good now:
temporary file: D:/grassdata/nc_spm_08_grass7/user1/.tmp/unknown/13920.3.csv
Warning message:
Finished running R.
(Thu May 31 22:12:30 2018) Command finished (2 min 45 sec)
best regards
Helmut
Le Thu, 31 May 2018 13:14:39 -0700 (MST),
>>> no problem.
>>> patch applied:
>>> Warning message:
>>> trainInfo, :
>>> "'D:\g"
>>> "'D:\g"
>> training_map=training train_class_colum=class processes=3
>> temporary file:
>>> getwd()
> Right.
> line 486 help ?
Great, thanks for the testing and feedback.
This said, if I understand the OP's message, the issue was in finding
Rscript in MS Windows. Do you have any recommendation on this ?
Moritz
looking at the original report:
pts/v.class.mlR.py", line 633, in <module>
    main()
pts/v.class.mlR.py", line 570, in main
  File "C:\Program Files\GRASS GIS
7.4.0\Python27\lib\subprocess.py", line 537, in check_call
7.4.0\Python27\lib\subprocess.py", line 524, in call
7.4.0\Python27\lib\subprocess.py", line 711, in __init__
    errread, errwrite)
7.4.0\Python27\lib\subprocess.py", line 948, in
_execute_child
    startupinfo)
specified
yes, it seems it's the issue finding the Rscript.
the tempfile and the path to it has to be properly build, acknowledging to
operating system characteristics; and, as in this case, considering the
peculiarity of involved 3rd party software.
e.g.
# path in windows
D:\temp\vclassr
vs.
# path in R in windows
D:/temp/vclassr
but don't be confused [1] [2], windows operating system also understands
D:/temp/vclassr, e.g. you can cd in the command line or open it in the
windows explorer ;-D ...
[1]
https://bytes.com/topic/python/answers/23123-when-did-windows-start-accepting-forward-slash-path-separator
[2]
https://www.howtogeek.com/181774/why-windows-uses-backslashes-and-everything-else-uses-forward-slashes/
best regards
Helmut
Am 31. Mai 2018 22:43:58 MESZ schrieb Helmut Kudrnovsky <hellik@web.de>:
   main()
   errread, errwrite)
_execute_child
   startupinfo)
specified
But it's not about the tempfile, it's about calling Rscript and Windows not being able to find it, or ? Some paths to set correctly maybe ?
Moritz
But it's not about the tempfile, it's about calling Rscript and >Windows not
looking closer at the report and the used command, the Rscript and other
files should be written to files in some folder, right?
What I've seen today during quick tests, it may be the path can't be
resolved, it may be a similar issue with path like for the temp File.
But in my first quuck test, the Rscript was written to a folder when
specified.
I suggest to apply a patch in svn to solve the temp file issue, then further
testing is needed.
best regards
Helmut
Rscript is an executable which allows to call R commands non-interactively in a scripting environment.
However, I noticed that the file with the R commands was the only one I hadn't done the replace("\\", "/") on, so maybe the error about not being able to find the file is about the command file, not Rscript.
  >Some paths to set correctly maybe ?
specified.
testing is needed.
I committed a patch in r72758 which now correctly applies the replace() call to all tempfiles created. Please test.
If you still see an error that combines
and
specified
Then maybe it is about Rscript not being in the PATH...
Jamille, could you please also test ? It should be available for Windows for installation with g.extension by tomorrow.
Moritz
