I am attempting to use the rmarea
tool in v.clean with a threshold of ~ 1000 sq meters.
projection is the following:
g.proj -p
-PROJ_INFO-------------------------------------------------
name : NAD83 / UTM zone 5N
datum : nad83
ellps : grs80
proj : utm
zone : 5
towgs84 : 0,0,0,0,0,0,0
no_defs : defined
-PROJ_EPSG-------------------------------------------------
epsg : 26905
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
I am getting a rather cryptic message ‘Failed to build area’.
v.clean -c --overwrite --verbose input=plot_pa_with_lidar@project_area output=plot_pa_rmarea tool=rmarea threshold=1017.2
Tool: Threshold
Remove small areas: 1017.2
WARNING: Vector map <plot_pa_rmarea> already exists and will be overwritten
Using native format
Copying features…
100%
Rebuilding parts of topology…
Building topology for vector map <plot_pa_rmarea@project_area>…
Registering primitives…
1720636 primitives registered
3439992 vertices registered
Building areas…
WARNING: Area of size = 0.0 ignored
100%
499671 areas built
6004 isles built
Attaching islands…
100%
Attaching centroids…
100%
Topology was built
Number of nodes: 728615
Number of primitives: 1720636
Number of points: 0
Number of lines: 0
Number of boundaries: 1222309
Number of centroids: 498327
Number of areas: 499671
Number of isles: 6004
WARNING: Number of incorrect boundaries: 9
WARNING: Number of duplicate centroids: 14
Tool: Remove small areas
ERROR: Failed to build new area
