[GRASS-user] v.color with layer 2
Hi to all
I have some problems with v.colors (grass6.5.svn) when I try to use it
with a vector on layer 2; I get this error:
DBMI-SQLite driver error:
Error in sqlite3_prepare():
near "mypoints2_2": syntax error
ERROR: Error while executing: 'UPDATE mypoints2
       mypoints2_2 SET GRASSRGB = '0:0:255' WHERE cat = 1'
ERROR: Processing SQL transaction
Here a little script that reproduces this error:
#!/bin/sh
# # spearfish60 dataset
db.connect database='$GISDBASE/$LOCATION_NAME/$MAPSET/mydbsqlite' driver=sqlite
g.copy vect=archsites,mypoints --overwrite
v.category in=mypoints layer=2 out=mypoints2 opt=add --overwrite
v.db.addtable mypoints2 layer=2
v.colors map=mypoints2 layer=2 color=bcyr column=cat
Where I'm wrong?
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
On Thu, Mar 19, 2009 at 8:58 AM, Paolo Craveri <pcraveri@gmail.com> wrote:
Hi to all
  mypoints2\_2 SET GRASSRGB = &#39;0:0:255&#39; WHERE cat = 1&#39;
Great - like this it was easy to reproduce here.
#!/bin/sh
Where I'm wrong?
You aren't. It was a bug which I have now fixed:
http://trac.osgeo.org/grass/changeset/36412
(also in the other branches).
Thanks for catching it,
