I’m having problem in assigning a raster color table to a vector map.
g.copy vector=roads,roads_copia (no color table)
v.colors map=roads_copia raster=slope (a color table is assigned)
v.colors map=roads_copia raster=soils (no color table assigned)
It seems that if the raster map contains integer values the colors are not assigned, but surely there is some other reason I don’t understand. Is there a place where the criteria of defining colors from a raster map to be assigned to a vector map are explained?
Thanks in advance
A. Clerici
This is a known issue:
https://trac.osgeo.org/grass/ticket/2556
but it would help if you could add your experience to that ticket.
Moritz
