[GRASS-user] v.colors rules
Hi to all
How v.colors with option rules works ?
I tried:
cat color.txt
1 red
2 green
3 blue
4 orange
5 purple
v.db.select mypoints
cat
5
1
4
3
2
v.colors map=mypoints column=cat rules=color.txt
ERROR: Pick one of color, rules, or raster options
v.colors map=mypoints color=rules column=cat rules=color.txt
ERROR: value <rules> out of range for parameter <color>
v.colors map=mypoints color=rules.txt
ERROR: value <rules.txt> out of range for parameter <color>
Thanks
Paolo C.
Lat. 44° 39' 11.08'' N Long. 7° 23' 25.26'' E
On Mon, 2009-02-09 at 12:12 +0100, Paolo Craveri wrote:
Hi to all
I tried:
cat color.txt
1 red
2 green
3 blue
4 orange
5 purple
cat
5
1
4
3
2
Thanks
Ciao Paolo.
It doesn't work for me either!
Nikos
# query samples_unburned6 for unique values in the 2nd column
v.db.select samples_unburned6 | cut -d"|" -f2 | sort -u
1
3
332
5
value
# v.colors with random (or other) colors works just fine
v.colors samples_unburned6 column=value color=random
# v.colors "rules=" or "raster" fails
# first the *rules*
cat samples_color.rules
-333 255:0:0
-331 0:255:0
1 255:0:0
2 255:255:0
3 0:255:0
5 0:0:255
332 200:200:200
334 0:0:0
# try to use "rules="
v.colors samples_unburned6 column=value rules=samples_color.rules
# list the colr file for some raster map
cat training_6_prefire
% -333 334
-333:255:0:0 -331:0:255:0
-331:0:255:0 1:255:0:0
1:255:0:0 2:255:255:0
2:255:255:0 3:0:255:0
3:0:255:0 5:0:0:255
5:0:0:255 332:200
332:200 334:0
# try to use "raster="
v.colors samples_unburned6 column=value raster=training_6_prefire
On Mon, Feb 9, 2009 at 12:12 PM, Paolo Craveri <pcraveri@gmail.com> wrote:
Hi to all
Paolo,
in line 160 of the script, can you change
   if [ -n "$OPTNAME" ] ; then
to
   if [ -z "$OPTNAME" ] ; then
and report back? For me it works like this (maybe it
breaks something else?!).
Hi to all
Paolo,
forget that.
The problem is that the color "bcyr" is predefined.
Try to deleted line 66:
#% answer: bcyr
and report back. Then it seems to work. I tested color= and
rules=.
Also added a new example to the manual page.
2009/2/9 Markus Neteler <neteler@osgeo.org>:
#% answer: bcyr
ok, done, but:
v.colors mypoints rules=color.txt column=cat
I commented lines from 163 to 166 (test over options) and works:
cat|GRASSRGB
5|127:0:255
1|255:0:0
4|255:127:0
3|0:0:255
2|0:255:0
ciao
Paolo C.
#% answer: bcyr
ok, done, but:
Are you sure that you ran
make
and, if needed,
make install
afterwards?
make
and, if needed,
make install
afterwards?
Ok now it works. Many thanks
Paolo C.
Perfect. Fixed in all relevant GRASS versions (SVN).
