[GRASS-user] v.colors usage
   The postgres table with station data has data type varchar(12) for the
column named bin_col but grass apparently doesn't see this:
# \d stations
bin_col | character varying(12)
# select bin_col from stations limit 3;
  bin_col ----------
  0:231:57
(3 rows)
v.colors -c map=stations use=attr column=site_nbr rgb_col=bin_col --o
Writing color rules...
ERROR: Data type of RGB column <bin_col> must be char
   Where have I made the syntactical mistake?
TIA,
Rich
   I slightly modified the command to use a different column:
v.colors -c map=stations use=attr column=howmany rgb_col=bin_col --o
Checking that grass saw the postgres table:
db.connect -p
driver: pg
database: willamette-river-hg
schema: group:
Yep, it does.
Looking at the table structure:
db.describe table=stations
table:stations
description:
insert:?
delete:?
ncols:10
nrows:82
column:howmany
description:
type:INTEGER
len:4
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:bin_col
description:
type:CHARACTER
len:12
scale:0
precision:0
default:
nullok:yes
select:?
update:?
   So, why does grass tell me the bin_col column needs to be CHAR when it is
(unless grass differentiates between char and CHARACTER.)
Rich
Hi Rich,
are there any entries in the table with bin_col is empty, i.e. null? I am not sure in this context, but I know from other cases that database driver failed in recognizing the datatype of a field while checking the first dataset in the table and the field was not set (i.e. null).
Regards.
Stefan
Rich Shepard <rshepard@appl-ecosys.com> hat am 6. November 2018 um 00:02 geschrieben:
> db.connect -p
driver: pg
schema:
group:
Yep, it does.
table:stations
description:
insert:?
delete:?
ncols:10
nrows:82
column:howmany
description:
type:INTEGER
len:4
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:bin_col
description:
type:CHARACTER
len:12
scale:0
precision:0
default:
nullok:yes
select:?
update:?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
On Tue, 6 Nov 2018, st_kiefer@web.de wrote:
Are there any entries in the table with bin_col is empty, i.e. null? I am
Stefan,
   No. There are only 82 rows in the table and the update command applied to
all rows, grouped first by 'site_nbr', then by the range of values in the
'howmany' column.
   I just checked (again) and every row has an entry for each column. Thanks
for the thought,
Best regards,
Rich
   This is interesting. In the ../scripts directory, along with the grass
script, is a file called 'rules.txt' with perms 644. Adding a rules= option
to the v.colors command removed the rgb_col data type error and replaced it
with two errors: 1) not finding a column in the table and 2) an inability to
read the rules.txt file:
v.colors -c map=stations use=attr column=howmany rules=rules.txt rgb_col=bin_col --o
ERROR: Column <howmany> not found in table <stations>
/home/rshepard/documents/white-papers/geochemistry/willamette-river-mercury/scripts/grass-display-sample-sites.sh:
line 12: /scripts/rules.txt: No such file or directory
   For error 1:
db.describe tab=stations
column:howmany
description:
type:INTEGER
len:4
scale:0
precision:0
default:
nullok:yes
select:?
update:?
   For error 2:
$ ll rules.txt -rw-r--r-- 1 rshepard users 187 Nov 6 08:34 rules.txt
   What might be going on here with 7.7.svn (r73645)?
Rich
On Tue, Nov 6, 2018 at 5:56 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
This is interesting. In the …/scripts directory, along with the grass
script, is a file called ‘rules.txt’ with perms 644. Adding a rules= option
ERROR: Column not found in table
For error 1:
column:howmany
description:
type:INTEGER
len:4
scale:0
precision:0
default:
nullok:yes
select:?
update:?
For error 2:
$ ll rules.txt
-rw-r–r-- 1 rshepard users 187 Nov 6 08:34 rules.txt
Please check v.db.connect map=stations -p
and
db.connect -p
Is the table attached to the map stations really in the default database?
Markus M
and
db.connect -p
Markus M,
   When I run db.colums without specifying the driver does grass display the
columns in the sqlite or postgres table?
db.columns table=stations
site_nbr
site_name
lon
lat
easting
northing
start_date
end_date
howmany
bin_col
   Adding the driver 'sqlite' suggests that db.columns sees the postgres
table:
db.columns table=stations driver=sqlite
WARNING: Table <stations> not found in database <willamette-river-hg> using
          driver <sqlite>
So, if the db.* modules look in the postgres database tables, why does the
v.db.* modules look in the sqlite table instead? And, trying to rewire the
attribute table for the stations map from sqlite to postgres fails:
v.db.connect map=stations driver=pg table=stations -o
ERROR: Column <cat> not found in table <stations>
   All suggestions welcome.
Rich
