I'm using GRASS 6.2.1 from Jachym Ubuntu repositories and v.db.addcol
with sqlite is behaving strangely.
First I created some random points (v.random) and created a table for
it in a sqlite database (v.db.addtable pontos). The table with the cat
col gets created OK. Now I want to sample some rasters with the points
so I first create a new column (v.db.addcol map=pontos column="teste
INT") and I get the following:
GRASS 6.2.1 (amazon):~/modis > v.db.addcol map=pontos column="teste INT"
/usr/lib/grass/scripts/v.db.addcol: 96: let: not found
DBMI-SQLite driver error:
Error in sqlite3_prepare():
duplicate column name: teste
ERROR: Error while executing: "ALTER TABLE pontos ADD COLUMN teste INT
ERROR: Cannot continue (problem adding column).
Funny thing is that the column does get created. I can see it with db.columns
Now, if I create the column with db.execute no error occurs.
I saw a similar problem reported last year but no solution in the mail tread.
Thanks
Daniel
