Hallo Grass'ers
I am having trouble with v.db.addcol. My vector has 315 discrete polygons (sample plots for LiDAR and MX data). I would like to add a column and populate it with numbers running from 1 - 315.
db.connect -p returns the following data
GRASS 6.2.3 (Paper4):~/paper4-data/work/sampling > db.connect -p
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
schema:(null)
group:(null)
and when I execute v.db.addcol I get the following error
GRASS 6.2.3 (Paper4):~/paper4-data/work/sampling > v.db.addcol map=Flight_line2_clean layer=1 column="ID,INT"
DBMI-DBF driver error:
SQL parser error in statement:
ALTER TABLE Flight_line2_clean ADD COLUMN ID
Error in db_execute_immediate()
ERROR: Error while executing: "ALTER TABLE Flight_line2_clean ADD COLUMN ID
ERROR: Cannot continue (problem adding column).
I have tried various combinations of the "column" variable as this is where I think the problem lies. I would like the column name to be ID and it to contain INTEGER values.
Could someone please suggest a solution
Many thanks and looking forward to your help and support,
Wesley
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
