Hi Everybody
I’ve got a little problem with the v.db.addtable command
when I make this
v.db.addtable map=toto layer2
I’ve got this
Using vector map name extended by layer number as table name: toto_2
Creating table with columns (cat integer)
WARNING: The table <toto_2> is now part of vector map and may be
deleted or overwritten by GRASS modules
WARNING: Select privileges were granted on the table
ERROR: G_calloc: out of memory
When I make test with the same command but with layer 1 on the same vector I’ve got no problem,
but when I want to add a second layer I’ve got this error (the command add a second layer but after I can’t update the second table). Even if I modify the extent of the region with g.region I’ve got the same error
I’m on Ubuntu Gutsy with GRASS 6.2.3 on a pc Intel Pentium 3.00 GHZ with 1000 Mo RAM
Can somebody help me ?
Mick
M.
