[GRASS-user] v.db.connect.all - errors
Hi all
I just tried to change all the vector maps of one location from DBF to SQLite, following this page: https://grasswiki.osgeo.org/wiki/Convert_all_GRASS_6_vector_maps_to_GRASS_7
these are the steps:
first rebuild topology for all vector maps in current mapset
v.build.all
define new default DB connection (switch from DBF to SQLite)
db.connect -d
transfer all attribute tables from DBF to SQLite and clean old DBF tables
v.db.reconnect.all -cd
steps 1 and 2 work fine, but #3 doesn’t v.db.reconnect.all -c
dbmi: db_list_databases() not implemented
ERROR: Unable to list databases. Try to define correct connection settings
by db.login.
File “/usr/local/Cellar/grass-70/7.0.3/grass-7.0.3/scripts/v.db.reconnect.all”, line 260, in
sys.exit(main())
File “/usr/local/Cellar/grass-70/7.0.3/grass-7.0.3/scripts/v.db.reconnect.all”, line 188, in main
create_db(new_driver, new_database)
File “/usr/local/Cellar/grass-70/7.0.3/grass-7.0.3/scripts/v.db.reconnect.all”, line 87, in create_db
driver = driver).splitlines():
File “/usr/local/Cellar/grass-70/7.0.3/grass-7.0.3/etc/python/grass/script/core.py”, line 445, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File “/usr/local/Cellar/grass-70/7.0.3/grass-7.0.3/etc/python/grass/script/core.py”, line 312, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None [‘db.databases’, ‘–q’, ‘driver=sqlite’] ended with error
Process ended with non-zero return code 1. See errors in the (error) output.
I’m running 7.0.3 installed via homebrew on Mac OSX
thanks
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
On Wed, Apr 13, 2016 at 10:33 PM, Carlos Grohmann
<carlos.grohmann@gmail.com> wrote:
Hi all
# first rebuild topology for all vector maps in current mapset
v.build.all
# define new default DB connection (switch from DBF to SQLite)
db.connect -d
Can you here please run
db.connect -p
to see what it picked up? (should be sqlite).
# transfer all attribute tables from DBF to SQLite and clean old DBF tables
steps 1 and 2 work fine, but #3 doesn't v.db.reconnect.all -c
       by db.login.
I think that this error got reported in the past on MacOSX:
So it would be important to know where it comes from (hence my
question above to get an idea).
here is the output:
GRASS 7.0.3 (latlong):~ > db.connect -p
driver: sqlite
database: /Volumes/MacintoshHD2/grassdata/latlong/base_maps/sqlite/sqlite.db
schema:
group:
thanks
Hi all
v.build.all
db.connect -d
db.connect -p
by db.login.
