[GRASS-user] v.db.join script
I apologise for possible double-posting - but it seems that I did not send the email copied below to the correct address. If anyone has experienced the v.d.b.join column definition/truncation problem desacribed belowl and has some advice, I would be very grateful to hear about it.
Best regards, Jon
I have a truncation problem with v.db.join. This has been raised before -
([GRASS-user] Re: grass v.db.join
Gary Nobles
Fri, 12 Mar 2010 11:11:26 -0800)
- but I have not seen a solution. I have tried my own data, the
spearfish60 example data, and the example in Neteler and Mitasova's book.
The new data columns are apparently defined as 1 character long, and the
data become truncated accordingly, much against my intention. I use mysql.
Can anyone point out a solution? I copy a session with the spearfish60
data below.
Jon
GRASS 6.4.0 (spearfish60):~ > g.copy vect=soils,mysoils
Copy vector <soils@PERMANENT> to current mapset as <mysoils>
GRASS 6.4.0 (spearfish60):~ > db.select mysoils
cat|label
1|Aab
2|Ba
3|Bb
4|BcB
5|BcC
6|BeE
GRASS 6.4.0 (spearfish60):~ > db.in.ogr soils_legend.csv out=soils_legend
Imported table <soils_legend> with 55 rows
GRASS 6.4.0 (spearfish60):~ > db.select soils_legend
id|shortname|longname
0|no data|no data
1|AaB|Alice fine sandy loam, 0 to 6
2|Ba|Barnum silt loam
3|Bb|Barnum silt loam, channeled
4|BcB|Boneek silt loam, 2 to 6
5|BcC|Boneek silt loam, 6 to 9
6|BeE|Butche stony loam, 6 to 50
GRASS 6.4.0 (spearfish60):~ > v.db.join mysoils col=label
otable=soils_legend ocol=shortname
GRASS 6.4.0 (spearfish60):~ > v.db.select mysoils
cat|label|id|shortname|longname
1|Aab|1|A|A
2|Ba|2|B|B
3|Bb|3|B|B
4|BcB|4|B|B
5|BcC|5|B|B
6|BeE|6|B|B
GRASS 6.4.0 (spearfish60):~ > db.describe -c mysoils
ncols: 5
nrows: 54
Column 1: cat:INTEGER:11
Column 2: label:CHARACTER:13
Column 3: id:CHARACTER:1
Column 4: shortname:CHARACTER:1
Column 5: longname:CHARACTER:1
GRASS 6.4.0 (spearfish60):~ > db.describe -c soils_legend
ncols: 3
nrows: 55
Column 1: id:CHARACTER:255
Column 2: shortname:CHARACTER:255
Column 3: longname:CHARACTER:255
Jon Eiriksson, Research Professor,
Earth Science Institute, University of Iceland,
Askja, Sturlugata 7,
IS-101 Reykjavik, Iceland.
Tel +354 525 44 75
Fax +354 525 44 99
Email jeir@hi.is
Web http://www.raunvis.hi.is/~jeir/
hear about it.
Best regards, Jon
before -
Gary Nobles
book.
mysql.
data below.
Hi Jon!
Not a direct solution but an alternative: Is mysql a requirement? What about
using sqlite? I think I have never seen this problem while using/ playing
around with sqlite.
Nikos
Hi Jon:
So we're pretty clear that this problem creeps up only on PostgreSQL and MySQL based vector layers. I checked in the documentation and both databases will create a *one* char wide column when the CHARACTER type is used without any size. Sqlite uses their "dynamic typing " so any CHAR column can be any size and the bug gets "hidden"...
Here's a new v.db.join script that seems to overcome the width problem. I tested *only* on a Postgresql based vector. It creates the full width columns like in the original table. Would you mind testing on MySQL? To use this scrpt, you'll have to drop it into your GRASS scripts directory (probably /usr/lib/grass64/scripts ) and make sure it's executable. Then run it as v.db.join2.
Additional note: If you're already using a spatial database, and you have external data tables to join, wouldn't the best workflow be to throw your new attributes into the database, and create a VIEW right in MySQL??
Micha
On 10/12/2010 12:01 PM, Jon Eiriksson wrote:
Gary Nobles
data below.
Jon
cat|label
1|Aab
2|Ba
3|Bb
4|BcB
5|BcC
6|BeE
0|no data|no data
1|Aab|1|A|A
2|Ba|2|B|B
3|Bb|3|B|B
4|BcB|4|B|B
5|BcC|5|B|B
6|BeE|6|B|B
ncols: 5
nrows: 54
ncols: 3
nrows: 55
Tel +354 525 44 75
Fax +354 525 44 99
Email jeir@hi.is
grass-user mailing list
grass-user@lists.osgeo.org
This mail was received via Mail-SeCure System.
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
(attachments)
v.db.join2 (4.04 KB)
Hi Micha,
I have tested v.db.join2 with mysql and it worked. No truncation! I am
using GRASS 6.4.0 on macosx.
I will think carefully about your workflow suggestion,
many, many thanks, Jon
Hi Jon:
MySQL??
Micha
Gary Nobles
book.
mysql.
data below.
Jon
cat|label
1|Aab
2|Ba
3|Bb
4|BcB
5|BcC
6|BeE
out=soils_legend
0|no data|no data
1|Aab|1|A|A
2|Ba|2|B|B
3|Bb|3|B|B
4|BcB|4|B|B
5|BcC|5|B|B
6|BeE|6|B|B
ncols: 5
nrows: 54
ncols: 3
nrows: 55
Tel +354 525 44 75
Fax +354 525 44 99
Email jeir@hi.is
Micha Silver
On Fri, Oct 15, 2010 at 2:08 PM, Micha Silver <micha@arava.co.il> wrote:
Hi Jon:
(Jon, sorry for my previous email, I missed this thread).
it as v.db.join2.
@Micha: Since Jon tested it on MySQL successfully, please consider to submit it
as patch to trac (please clean it up a bit then).
thanks
