[GRASS-user] v.db.select
How was the mean calculated from the table below? these are the output of v.db.select from v.rast.stats.
Cat
n
min
max
range
mean
stddev
variance
coeff-va
sum
26
1126
78
97
19
86.59
9.46
89.42
10.92
97499
Kind Regards
TS Gumede | CSIR | Meraka Institute | ICT4EO Research Group
Office Tel: 012 841 2606 | mobile : 072 258 1650
“Work like a slave in order to live like a King” ~ Unknown
Hi! As far as I understand, v.rast.stats is a script calling r.mapcalc to
perform the calculations. Subsequently, calculations depend on the raster
map(s) (size, resolution, data type, etc.)
Regards, Nikos
