I’m trying to use v.delaunay to get the lines connecting centroids in thiessen polygons because I need to compute some statistics on the length of those segments.
I’m facing a problem that maybe somebody could help me to solve.
Basically I run v.delaunay with the -l option to get lines instead of the polygons, I get the resulting vector, but there is no attribute tables associated to it.
My idea was to run v.db.addtable to create a new empty attribute table, then v.category to assign cat numbers and the v.to.db to compute and add to the attribute table the parameter I need (ie the length).
The problem is that when I run v.category nothing happens, and the attribute table remains empty.
Hello,
as attributes belong to triangle froming nodes, how should output look
like? Every triangle should get all three atributes? And what about
lines? Two attributes, as every triangulation line has two nodes at
their end?
Maris.
2011/3/30, Andrea Pogliaghi <andrea.pogliaghi@gmail.com>:
associated to it.
Ing. Andrea Pogliaghi
Milano - Italy
On Thu, Mar 31, 2011 at 10:25 AM, Maris Nartiss <maris.gis@gmail.com> wrote:
Hello,
their end?
It makes sense that no attribute is associated to v.delaunay lines output because the features (lines in my case as I’m using the -l switch) are different from the nodes (even if having an output attribute table containing, for instance, the attributes of the two nodes of each line would be useful), but that is not the point.
The issue I’m facing is that I want to create a new attribute table for these delaunay_lines with a new unique cat value for every line and compute the length of each line, as I need to know which is their min, max and avg.
associated to it.
Hello,
You have to connect Your vector map to database at first. Go to
Databases->Manage database->New table (v.db.addtable) and run
v.category afterwards.
Maris.
2011/3/31, Andrea Pogliaghi <andrea.pogliaghi@gmail.com>:
Hi Maris,
Hello,
their end?
because the features (lines in my case as I'm using the -l switch) are
The issue I'm facing is that I want to create a new attribute table for
Maris.
> Hi all,
> the
> associated to it.
> Milano - Italy
Hello,
That is exactly what I did. In fact in my first message I wrote
“My idea was to run v.db.addtable to create a new empty attribute table, then v.category to assign cat numbers and the v.to.db to compute and add to the attribute table the parameter I need (ie the length).
The problem is that when I run v.category nothing happens, and the attribute table remains empty.”
Hello,
their end?
the
associated to it.
Milano - Italy
just to make it clearer… if I do the above steps with v.delaunay, then I create the table with v.db.addtable and then I run v.category, it works fine.
If I do the same steps with v.delaunay with the -l flag (and I have to, since I need the lines), then it doesn’t.
Hello,
their end?
the
associated to it.
Milano - Italy
No database record
East: 624612.52163184
North: 6400722.66817441
Map: delone_cat
Mapset: rm_this2
Type: Line
Garums: 639.105487
Layer: 1
Category: 859
Driver: dbf
Database: /home/maris/grass_data/Vidzeme_Balt93/rm_this2/dbf/
Table: delone_cat
Key column: cat
Maris.
just to make it clearer.... if I do the above steps with v.delaunay, then I
fine.
since I need the lines), then it doesn't.
cheers
On Thu, Mar 31, 2011 at 4:37 PM, Andrea Pogliaghi <
andrea.pogliaghi@gmail.com> wrote:
On Thu, Mar 31, 2011 at 2:54 PM, Maris Nartiss <maris.gis@gmail.com>wrote:
Hello,
"My idea was to run v.db.addtable to create a new empty attribute table,
to
attribute table remains empty."
cheers
andrea
Maris.
> Hi Maris,
wrote:
>> Hello,
>> their end?
output
would
compute
avg.
> Cheers,
> Andrea
>> Maris.
>> > Hi all,
>> > of
>> > the
tables
>> > associated to it.
>> > Milano - Italy
