[GRASS-user] v.delaunay3d compilation issues
Hi list,
I’m having some trouble compiling the add-on v.delaunay3d on a 7.6.1 GRASS GIS install under Ubuntu. Running g.extension I get the following error messages:
g.extension extension=v.delaunay3d operation=add
Fetching <v.delaunay3d> from GRASS GIS Addons repository (be patient)…
Compiling…
In file included from
/usr/lib/grass76/include/grass/vect/digit.h:3:0,
from
/usr/lib/grass76/include/grass/vector.h:4,
from main.cpp:26:
/usr/lib/grass76/include/grass/vect/dig_structs.h:27:10:
fatal error: ogr_api.h: No such file or directory
#include <ogr_api.h>
compilation terminated.
make: *** [OBJ.x86_64-pc-linux-gnu/main.o] Error 1
ERROR: Compilation failed, sorry. Please check above error messages.
Any ideas on how to resolve this compilation issue would be appreciated.
Thank you.
Rob
út 26. 3. 2019 v 17:20 odesílatel Robert Dzur <rdzur@bhinc.com> napsal:
try to install `libgdal-dev` package. Ma
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin, thanks for your response.
Yeah...I actually have libgdal-dev (2.4.0) package installed; and still see this issue.
Thanks again.
Rob
-----Original Message-----
Sent: Tuesday, March 26, 2019 11:56 AM
To: Robert Dzur <rdzur@bhinc.com>
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] v.delaunay3d compilation issues
Martin Landa
út 26. 3. 2019 v 19:07 odesílatel Robert Dzur <rdzur@bhinc.com> napsal:
check header location:
$ dpkg -L libgdal-dev | grep ogr_api
/usr/include/gdal/ogr_api.h
$ g.extension v.delaunay3d --v
c++ -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2
-fdebug-prefix-map=/build/grass-8Jl1TI/grass-7.6.1=.
-specs=/usr/share/dpkg/no-pie-compile.specs -fstack-protector-strong
-Wformat -Werror=format-security -I/usr/lib/grass76/include
-I/usr/lib/grass76/include -frounding-math -DPACKAGE=\""grassmods"\"
-I/usr/include/postgresql -I/usr/lib/grass76/include
-DRELDIR=\"/tmp/grass7-martin-628/tmpHLuA32/v.delaunay3d\" -o
OBJ.x86_64-pc-linux-gnu/main.o -c main.cpp
so apparently `-I/usr/include/gdal` is missing. Should be fixed in
r74306. Try to run g.extension command again.
Ma
Martin Landa
Thank you Martin,
That appears to have resolved the issue as running g.extension again now reports successful installation:
Compiling…
ERROR: Variable ‘LOCATION_NAME’ not set
Installing…
Updating addons metadata file…
Installation of <v.delaunay3d> successfully finished
Thanks again,
Rob
Sent: Tuesday, March 26, 2019 12:29 PM
To: Robert Dzur
út 26. 3. 2019 v 19:07 odesílatel Robert Dzur rdzur@bhinc.com napsal:
Yeah…I actually have libgdal-dev (2.4.0) package installed; and still see this issue.
-I/usr/lib/grass76/include -frounding-math -DPACKAGE="“grassmods”"
-DRELDIR="/tmp/grass7-martin-628/tmpHLuA32/v.delaunay3d" -o
so apparently -I/usr/include/gdal is missing. Should be fixed in
Ma
Martin Landa
út 26. 3. 2019 v 19:46 odesílatel Robert Dzur <rdzur@bhinc.com> napsal:
ERROR: Variable 'LOCATION_NAME' not set
well, are you running g.extension from a GRASS session (location/mapset)?
Ma
Martin Landa
Hi Martin,
Yes, g.extension was run from a location in the PERMANENT mapset.
Rob
Sent: Tuesday, March 26, 2019 1:26 PM
Ma
Martin Landa
út 26. 3. 2019 v 21:13 odesílatel Robert Dzur <rdzur@bhinc.com> napsal:
sorry, I cannot reproduce this issue. But it seems that v.delaunay3d
has been successfully installed, right? Ma
Martin Landa
Hi Martin,
Yes it does appear that it has compiled and is functioning fine. I’ll have to spend a little time exploring the module with some test data but it’s looking like it’s working well. I imported a small 3D line file, converted to points (843) with v.to.points and the ran the triangulation (-l flag) of ~12k triangles with immediate results. Thanks again for your kind assistance.
Rob
Sent: Tuesday, March 26, 2019 2:16 PM
To: Robert Dzur
út 26. 3. 2019 v 21:13 odesílatel Robert Dzur rdzur@bhinc.com napsal:
Martin Landa
