while digitizing roads for a watershed, the v.digit module stopped responding. Nothing worked, so i had to restart GRASS. Then, i rebuilt the topology of the vector file, but when i started the v.digit again, i got this message:
v.digit map=roads bgcmd="d.rast comptopo53j3"
WARNING: coor files of vector 'roads@datta' is larger than it should be
(152007 bytes excess).
100%
The file seems to work fine and without any problem, but I want to be sure that ignoring this message cannot cause some problems later. Could anybody please explain why this happens (it has happened quite a no. of times now) and give some possible suggestions.
What version of GRASS? There have been big structural changes to v.digit
in the 6.3 development version recently, which hopefully solves several
problems in the 6.2 version.
What were you doing at the time of lock-up? How many features digitized
in the session? Started from a new map? DB table? etc. Maybe we can get
a better idea where it happens, then we can look for why.
You are not the first person to report v.digit lockups, but I've never
seen it happen myself.
should be
100%
starting v.digit and then exiting v.digit will make the warning go away.
for other errors (but not this one) v.build can help too.
later.
after loading & saving it with v.digit it should be fine.
any data loss?
suggestions.
Don't know why it happens, maybe you can help us figure that out by
trying to figure out the steps to easily reproduce it.
I got two computers (both ubuntu edgy, grass 6.2.1) working on the same grass project (not simultaneously, one at home, one at work). However, the users are named different, so the $GISDBASE is as following:
Now user2 has a problem with d.vect. Whenever querying something from a vector, there goes the error "DBMI-DBF driver error: cannot open database: /home/user1(!)/database/location/mapset". db.connect is set correctly to '/home/user2/...' Is there another connection of databases to be done?
following:
