Hello!
I'm like try Grass, but the v.digit not work:
--> grass60
GRASS 6.0.2 > v.digit map=utcak
Segmentation fault (core dumped)
--> gdb /usr/local/grass/bin/v.digit -core=v.digit.core
(gdb) bt
#0 0x0000000802084cb0 in strlen () from /lib/libc.so.6
#1 0x0000000801e582d1 in Tcl_ExternalToUtfDString ()
from /usr/local/lib/libtcl84.so.1
#2 0x0000000801b43f1d in Tk_MainEx () from /usr/local/lib/libtk84.so.1
#3 0x0000000000409f30 in main ()
--> ldd /usr/local/grass/bin/v.digit
libtcl84.so.1 => /usr/local/lib/libtcl84.so.1 (0x801e0c000)
libtk84.so.1 => /usr/local/lib/libtk84.so.1 (0x801afe000)
--> nm /usr/local/grass/bin/v.digit | grep Main
U Tk_MainEx
pkg_info
tcl-8.4.11,1
tcl-8.3.5_5
tk-8.4.13,2
tk-8.3.5_5
grass-6.0.2,2
I try packet and port (all tcl, tk and grass), but the Grass not run
neither.
the OS= FreeBSD 6.1-amd64
Can you help me? I'm a beginer Unix* user, therefore I like you will
write example.
