[GRASS-user] v.digit
Hello,
I try v.digit; i want to define a new outline. When i want to close the outline, it opens a window form: attributes; new record was created. Assume data encoding as: [choice between utf-8,ascii,iso88859-1,koi8-t]; i do submit and i have the error:
Cannot update table:
DBMI-DBF driver error:
SQL parser error in statement:
update australia set where cat = 4
Error in db_execute_immediate()
Could you help me?
Thank you
On Thu, 2009-02-19 at 17:28 +0100, FAROUX STEPHANIE wrote:
Hello,
Could you help me?
Thank you
First things to try:
db.connect -p
v.db.connect -g YourVectorMap
Nikos
Hello,
Could you help me?
Thank you
db.connect -p
Nikos
Yes i forgot to connect but it isn't enough to work...
I also try db.tables but i have the error:
Cannot open dbf database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/australia.dbf
FAROUX STEPHANIE:
>> Hello,
> db.connect -p
Is the table in the database already present?
# check with
db.tables -p
# if not, then
v.db.addtable YourVectorMap
# if it is... then (shrug)
On Thu, 2009-02-19 at 17:56 +0100, Nikos Alexandris wrote:
FAROUX STEPHANIE:
> >> Hello,
> > db.connect -p
Ah, ok! Sorry...
What exactly does db.tables -p say?
Did you move the (grass-)database to another directory from last time
you worked in this location?
And... what exactly does db.connect -p say?
driver:dbf
database:$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/australia2.dbf
schema:(null)
group:toto
I destroyed my vector layer and tried to make a new one...
Is there a place in the documentation where this action is described? For the moment i have no database in the dbf directory. I don't remember how i get one before (i had the database before i destroy my vector)
driver:dbf
schema:(null)
group:toto
If you still have the initial database then you just need to re-connect
to it. _If_ I am guessing right (right now, from memory) you have to
execute something like:
v.db.reconnect.all old_database=
new_database=database:
Hopefully this helps. If not then I will try to have a more precise look
at it later, or a grass-db magician on the list can solve this out.
Kind regards, Nikos
2009/2/19 FAROUX STEPHANIE <stephanie.faroux@meteo.fr>:
group:toto
What is group 'toto'?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Martin Landa wrote:
group:toto
Martin
nothing
On Thu, Feb 19, 2009 at 6:14 PM, FAROUX STEPHANIE
driver:dbf
schema:(null)
group:toto
Please don't define a file name as database. It must be the *directory*:
db.connect -p
driver:dbf
schema:
group:
Then it will work. So:
db.connect driver=dbf database='$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'
db.tables -p
> driver:dbf
> schema:(null)
> group:toto
db.connect -p
driver:dbf
schema:
group:
db.tables -p
Right. I was writing from memory.
"update australia set where cat = 4" is missing something between "set"
and "where". set what?
Hamish
Hamish
Yes i know it isn't right. I will see this problem next. For the moment grass fails to run... :frowning:
driver:dbf
schema:(null)
group:toto
db.connect -p
driver:dbf
schema:
group:
db.tables -p
Ok it works; now i have a little problem: i try to make a outline and i have difficulty to close it. My map is global at 1/120° resolution; maybe it's linked to the big distances?
I changed the threshold in the settings but it doesn't seem to be enough....
Thank you
when i want to save a new vector. But the vector is created.
Stephanie:
What kind of settings? "g.region -p"?
If you need a _frame_ (=vector) you can use "v.in.region" and for a grid
"v.mkgrid".
Nikos
Stephanie:
"v.mkgrid".
Nikos
Nono i try to make a outline vector and i talk about the settings of the v.digit function
Snapping has never worked correctly for me in the gis.m digitizer. Work-around is to draw the boundaries and then move one of the nodes which you want to snap to the other. Sometimes, you have to move it away a bit before moving it back towards the other node, and then snapping works.
It works very well in the new wxGUI, which I would generally recommend as being superior to the old digitizer.
Moritz
