[GRASS-user] v.dissolve and SQLite
After:
# v.patch -e input="x75@cos90,x84@cos90,x85@cos90,x94@cos90,x95@cos90"
output="cos90_patch"
# v.clean input="cos90_patch@cos90" output="cos90_clean"
type="point,line,boundary,centroid,area" tool="break,snap,rmdupl,bpol"
thresh=0.01
# v.dissolve input=cos90_clean@cos90 output=cos90_diss column=LEG
...gives me this error:
DBMI-SQLite driver error:
Cannot step:
SQL logic error or missing database
ERROR: Unable to fetch data from table <cos90_clean>
ERROR: Unable to open vector map <cos90_diss_11516@cos90> on level 2.
Try to rebuild vector topology by v.build.
ERROR: Vector map <cos90_diss> not found in the current mapset
An similar error is documented.
http://trac.osgeo.org/grass/ticket/548
Any idea?
I'm going to try the same operations with a postgres connection.
Luís Ferreira
2009/11/21 Luís Ferreira <lferreira75.1@gmail.com>:
Any idea?
right, the bug still waits to be be fixed. PostgreSQL backend should work.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Yes, connecting to postgresql solved the problem.
Luís
On Sat, 2009-11-21 at 20:48 +0100, Martin Landa wrote:
> Any idea?
Martin
