[GRASS-user] v.dissolve bugfeature / workaround needed
Hello list,
i am using GRASS 6.4svn to merge adjacent poylgons into larger units. The merging is controlled by a column of type CHAR:
v.dissolve input=counties output=counties_merged_fips1 column=FIPS_1
results in
dbmi: Protocol error
ERROR: Cannot open select cursor: SELECT cat, FIPS_1 FROM counties
       ORDER BY FIPS_1
ERROR: Unable to open vector map <counties_fips1_22157@admin_borders>
       on topology level 2
WARNING: Table <counties_fips1_22157> linked to vector map
         <counties_fips1_22157> does not exist
ERROR: Vector map <counties_fips1> not found in the current mapset
v.dissolve works correctly when applied to an INT column.
I assume this is a bugfeature - string-based dissolving would be great to have at some point.
For now, does anybody have a (DBdriver-)SQL-hack to transmogrify strings like "GRASS001", "GRASS002", "GRASS003" into the Integers 1,2,3 ? (aka getting rid of the "GRASS"-part of the string) ?
Peter
Dr. Peter Löwe
<peter.loewe@gmx.de>
GMX startet ShortView.de. Hier findest Du Leute mit Deinen Interessen!
Jetzt dabei sein: http://www.shortview.de/wasistshortview.php?mc=sv_ext_mf@gmx
On 06/08/08 15:09, peter.loewe@gmx.de wrote:
Hello list,
results in dbmi: Protocol error ERROR: Cannot open select cursor:
SELECT cat, FIPS_1 FROM counties ORDER BY FIPS_1 ERROR: Unable to
open vector map <counties_fips1_22157@admin_borders> on topology
level 2 WARNING: Table <counties_fips1_22157> linked to vector map <counties_fips1_22157> does not exist ERROR: Vector map
v.dissolve is only a frontend script to v.reclass which needs ints...
+1
If you absolutely need to work with the dbf-driver, then I guess you best bet would be to open the dbf file in OpenOffice Calc and use its functions.
If you can switch over to SQLite, I think the ltrim function should do what you need.
More full-fledged SQL-backends obviously have more sophisticated functions.
Moritz
Hi Peter,
Following Morit´z suggestion, how about you use R on this task?
#The code below is to you read your dbf file
#so remove the # and include your full path/file name
#require(foreign)
#my.dbf<-read.dbf(“c:/temp/myfile.dbf”) #
#below we simulate a data.frame (it is a table)
my.dbf<-data.frame(cbind(var1=c(“GRASS001”,“GRASS002”,“GRASS003”)))
my.dbf
#below you have a code to “deparse” your variable of interest
my.dbf$var2_char<-substr(my.dbf$var1,6,999)
my.dbf
my.dbf$var2_int <-as.numeric(as.character(my.dbf$var2_char))
my.dbf
miltinho
brazil
2008/8/6, Moritz Lennert <mlennert@club.worldonline.be>:
Hello list,
v.dissolve is only a frontend script to v.reclass which needs ints…
+1
strings like “GRASS001”, “GRASS002”, “GRASS003” into the Integers
1,2,3 ? (aka getting rid of the “GRASS”-part of the string) ?
Moritz
grass-user mailing list
grass-user@lists.osgeo.org
There is a long tread about this...
http://thread.gmane.org/gmane.comp.gis.grass.user/21875/focus=21887
In the end I was under the impression that v.dissolve did work with
string data, as Hamish wrote:
http://article.gmane.org/gmane.comp.gis.grass.user/21920
But, I'm not sure if the column has to be type varchar or something else?
Anyway, if you are using dbf database, just open it in openoffice
(calc or base) and add a neu integer column with the values you want
for dissolve
cheers
daniel
On Wed, Aug 6, 2008 at 1:40 PM, Milton Cezar Ribeiro
<miltinho.astronauta@gmail.com> wrote:
Hi Peter,
#require(foreign)
#my.dbf<-read.dbf("c:/temp/myfile.dbf") #
my.dbf<-data.frame(cbind(var1=c("GRASS001","GRASS002","GRASS003")))
my.dbf
#below you have a code to "deparse" your variable of interest
my.dbf
my.dbf
miltinho
brazil
Hello list,
+1
what you need.
functions.
Moritz
Hello Milton,
thanks for that beautiful R-hack !
Since I am working on a minimal "bread and butter" machine I went for Moritz' solution but it's a neat idea to use R for the task.
Eventually, GIS-hacking should become part of the Olympics and you all should try to get medals :slight_smile:
Peter
-------- Original-Nachricht --------
Datum: Wed, 6 Aug 2008 13:40:35 -0300
Von: "Milton Cezar Ribeiro" <miltinho.astronauta@gmail.com>
An: "Moritz Lennert" <mlennert@club.worldonline.be>
CC: peter.loewe@gmx.de, grass-user@lists.osgeo.org
Betreff: Re: [GRASS-user] v.dissolve bugfeature / workaround needed
Hi Peter,
#require(foreign)
my.dbf
my.dbf
my.dbf
miltinho
brazil
>> Hello list,
> +1
best
functions.
what
> you need.
functions.
> Moritz
Dr. Peter Löwe
Psssst! Schon das coole Video vom GMX MultiMessenger gesehen?
Der Eine für Alle: http://www.gmx.net/de/go/messenger03
On 07/08/08 17:20, Peter Löwe wrote:
Hello Milton,
Actually, I stand corrected. Daniel was right: v.reclass does allow character columns and v.dissolve, therefore, does as well. I just tested with a map as it works with current svn trunk and and old pre-release 6.3:
> v.info -c NUTS2_2006
Displaying column types/names for database connection of layer 1:
INTEGER|cat
INTEGER|objectid
CHARACTER|cntr_code
INTEGER|stat_levl_
CHARACTER|nuts_id
DOUBLE PRECISION|shape_leng
DOUBLE PRECISION|shape_area
> v.dissolve in=NUTS2_2006 col=cntr_code out=countries
And I get a nice countries map...
So your error message is a bug:
Could you post the output of 'v.info -c counties' ?
Moritz
Hello Moritz and Peter,
I have the v.dissolve problem too. I'm running GRASS 6.4.svn (is there a way to tell what svn revision I'm using?) on Hardy Heron X86_64. Hope this info tells you something:
> v.dissolve input=alquist_priolo_eq_zones_mrg_ll83@PERMANENT output=efz layer=1 column=FaultName
Segmentation fault
ERROR: Cannot open select cursor: SELECT cat, FaultName FROM
       alquist_priolo_eq_zones_mrg_ll83 ORDER BY FaultName
ERROR: Unable to open vector map <efz_24149@PERMANENT> on topology level 2
WARNING: Table <efz_24149> linked to vector map <efz_24149> does not exist
ERROR: Vector map <efz> not found in the current mapset
> v.info alquist_priolo_eq_zones_mrg_ll83
| Layer: alquist_priolo_eq_zones_mrg_ll83 |
| Mapset: PERMANENT |
| Database: /home/bobm/Data/Grass |
| Title: |
| Map scale: 1:1 |
| Map format: native |
| Name of creator: bobm |
| Organization: |
| Source date: Fri Nov 17 11:47:54 2006 |
| Type of Map: vector (level: 2) |
| Number of points: 0 Number of areas: 2242 |
| Number of lines: 0 Number of islands: 788 |
| Number of boundaries: 4630 Number of faces: 0 |
| Number of centroids: 2224 Number of kernels: 0 |
| Map is 3D: 0 |
| Number of dblinks: 1 |
| Projection: Lambert Conformal Conic |
| N: 4959352.74991602 S: 3929916.63677083 |
| E: 341967.39773093 W: -438465.59887675 |
| Digitization threshold: 0 |
| Comments: |
> v.info -c alquist_priolo_eq_zones_mrg_ll83
INTEGER|cat
DOUBLE PRECISION|ID
CHARACTER|COUNTY
CHARACTER|QUADNAME
CHARACTER|FaultName
CHARACTER|HistoricSR
Bob Moskovitz
Research Analyst I
Seismic Hazard Evaluation Project
California Geological Survey
http://gmw.consrv.ca.gov/shmp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
-----Original Message-----
[mailto:grass-user-bounces@lists.osgeo.org]On Behalf Of Moritz Lennert
Sent: Thursday, August 07, 2008 8:45 AM
To: Peter Löwe
Cc: grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] v.dissolve bugfeature / workaround needed
> Hello Milton,
the task.
just tested
pre-release 6.3:
INTEGER|cat
INTEGER|objectid
CHARACTER|cntr_code
INTEGER|stat_levl_
CHARACTER|nuts_id
Unable to
vector map
Moritz
Moskovitz, Bob pisze:
In the directory with GRASS source code check the .svn/entries file. 4th
line from top carries the revision number.
Segmentation fault
Does this happen with all vector maps? If not, please report to Trac and
provide the sample data to reproduce the problem (a location that
contains the PERMANENT mapset alone with only the problematic vector map
inside).
Maciek
Maciej Sieczka
www.sieczka.org
Since yesterday it is also reported in the 6.4.svn source code in:
include/gis.h
#define GIS_H_VERSION "$Revision: XXXXX $"
