[GRASS-user] v.dissolve on multiple items/controlling the output
Hello list,
I have two questions concerning v.dissolve. As far as I can see, there can be only one single column be specified as dissolve item. But I need to dissolve polygons using several items (up to 6) in one stroke. I checked out v.extract, too, hoping that a SQL statement might help me out, but I can only use a WHERE clause (not a GROUP BY clause). Maybe it could help to produce one special concatenated dissolve item before running v.dissolve, but I was hoping to find a more „elegant“ way.
Second, how can I determine if the output of v.dissolve is Multipart or Singlepart? In my special case, I need both (one for map labeling, one for area statistics). I could not find an option to set Singlepart or Multipart.
Thanks a lot and best regards, Uwe
On 29/04/16 08:20, Uwe Fischer wrote:
Hello list,
How about creating a new attribute column which you can populate with a code that represents the result of the combination of your criteria. Then you can use v.dissolve with that column.
Multipart.
AFAIK, there is no such thing as multipart or singlepart in the GRASS vector format. You can characterize several polygons as representing one single entity (and link them to a single line in the attribute table) by giving them all the same category number. So, for example, if you have a vector with one attribute column containing a code identifying such multipart entities, you can create a new vector map with same category values (aka id's) for all polygons of the same entity using v.reclass (you can actually directly formulate SQL queries in the rules file you can feed to v.reclass - see the man page for more info).
Moritz
