[GRASS-user] 'v.distance'
Dear List,
I have a points vector file, which I use as input in ‘v.distance’ to create a new vector file of lines (showing the minimum distance to the coast). The output is naturally a vector file that contains lines between each point and the sea. However, I realize that the output map cannot be queried. Even if I have GRASS connect the new (lines) vector file with the points as the second layer, querying of the lines does not return results.
What I want to do is to assign CAT numbers to each line (it can be same with the CAT# of its point of origin) so that I can display lines individually in the new lines vector file for further analyses.
Thank you for your help!
Bulent
