Hello,
Just a little question,
what exactly does the threshold values mean in combination with the break-tool (v.edit)?
Default it is set to -1,0,0 Which units are that? What exactly does the -1 one mean (difference between neg. and. pos.)?
I've problems (kind of weird connections) with breaking very short lines if the default is set (-1), if I change it is also not working properly. I just tried playing around with values but if someone could explain what the coordinates-threshold value means in combination with break that could help me.
cheers
/johannes
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
